Results 1 to 10 of 19
January 8th, 2006 10:30 PM #1
I've been using my ride for 1 year and 4 months now with 10,300kms ODO reading. Most of the PM has been done except for the radiator flushing. Do I really need to do it? How often should it be done?
January 9th, 2006 10:45 AM #4
I think they are adding some sort of a flushing additive and circulate it to your car's cooling system. Is that additive not harmful to the radiator? I remember once my brother-in-law had his mazda 323 radiator flushed in a gasoline station. After few days, his radiator started leaking. Because of that, I' thinking of just draining my radiator of old coolant and fill up with fresh water, circulate for few minutes and drain it again.Then add a fresh mixture of water and coolant. Will that be okay guys?
January 9th, 2006 01:22 PM #5
20K for me (per advise of Service Manual). IMO, if you flush regularly you don't really need to use those additives... we might not know the long term effects of these in the cooling system since flushing additives usually can be corrosive or strong.
January 9th, 2006 01:59 PM #6
Once a year regardless of mileage for me... Just drain, stick a hose into the rad until clear water comes out, then replace coolang/water.
January 9th, 2006 08:34 PM #8
Don't forget to drain the water in the engine block. You have to flush the cooling system as a whole. This often involves locating for the coolant plug on the engine block itself.
Once you have drained the system and are in the process of refilling it, you should start the engine to let the thermostat open and let coolant into the water jackets.
Mechanics, please chime in kung mali yung procedure ko.
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 11th, 2006 10:06 AM #10no need na siguro to drain everything in the block. i mean it's ok if you really want to pero not worth the hassle imo.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
