Results 1 to 9 of 9
- May 2008
- 33
February 2nd, 2009 02:06 PM #1Me tagas po ng raditor coolant sa may hose na nakakabit sa water pump. My ride is a corolla gli 95 model.Ask ko lng po kung paano pinapalitan yung hose ? Sabi po kasi ng mekaniko na tumingin eh kelangan baklasin yung water pump pati na rin yung timing belt para maikabit yung bago na hose. Ganun po ba talaga ang pagpalit nun?Pwede bang derecho palitan without
disassembling the water pump at timing belt?Thanks in advance
February 3rd, 2009 03:06 AM #2
If water pump is okey,then no! Remove the old hose put the new one in, simple is that.
Oh one more thing stay away from that person.
THE AUTO SPECIALIST
- Mar 2006
- 607
February 3rd, 2009 09:21 AM #3kung yung elbow na hose na nakakabit sa water pump housing ang may leak,
mahirap talaga na palitan yun at kung time na sa timing belt maintainace , mas maigi kung palit na ang WP,T-BELT ,CRANK SEAL, CAM SEAL at oil pump seal pati na yung idler pulley .
- May 2008
- 33
February 3rd, 2009 01:11 PM #4Thanks po sa reply. I had my timing belt replaced last Apr 08. Then my water pump just Dec 08 because of bearing noise. Hinayang po kasi ako na pa-baklasin ulet yung water pump at timing belt just to replace the hose. BTW, do po cya elbow yung hose - straight hose lang po na halos 3 inches ang haba. Tapos nakakabit mismo sa water pump at aluminum sink ba yun na nakakabit sa engine lapit dun sa temperature sensor.(dont know exactly what it is). TIA.
- May 2008
- 33
February 6th, 2009 02:35 PM #6
december 08 lang pala pinalitan yung WP mo. so talagang hose yan.
di kailangan baklasin ang WP to install the hose. tanggal kabit lang yun.
February 7th, 2009 06:05 AM #7
Baka naman fan belt o aircon belt ang sinasabi niya. Maaari. Buti di sinabi ibaba natin ang makina para madaling tanggaling ang hose :D
- May 2008
- 33
February 7th, 2009 07:47 PM #8Hi,naayos na po yung tulo sa hose sa may water pump ..di po binaklas water pump at timing belt ..bale ginawan ng paraan ng mekaniko ko sa shell almanza ...tanggal baklas lng. Thanks sa mga suggestions.
March 7th, 2009 07:47 AM #9
can you recommend a trusted shop in banawe you can recommend mga sir for this kind of work?
