Results 1 to 9 of 9
- Apr 2005
- 18
April 28th, 2005 09:44 AM #1How much estimated cost to replace all "cooling hoses"?
Wahts the working fluid in this system - tubig din?
Had my civic'97 PM at Honda Alabang, guys said i need to replace hoses on next check-up.
- May 2004
- 36
April 28th, 2005 08:59 PM #2the quote 2 years ago to replace all the hoses is 4k at Honda Alabang. Medyo masakit, so kinalumutan ko muna. Up to now, okay pa naman. Your call.
Btw, 99 Civic yung sa akin.
April 29th, 2005 01:42 AM #3
Fluid in system is ideally a mix between distilled drinking water (distilled para walang solids) and ethelyne glycol based coolant. Mix 50/50.
Radiator hoses cost only a hundred or so sa auto supply.
- Oct 2004
- 132
April 29th, 2005 11:24 AM #4Palitan mo na yan mga hoses bro as soon as possible. Sa kin tumagas na nung isang araw. I have a thread here also about hoses... heheh... si sir otep master yan..:-) Mahirap nang abutan ka between long drives...mabuti sa kin asa bahay na ko at d p tuluyan nagoverheat dahil lumabas na coolant ko.
FYI. We have the same car.
- Apr 2005
- 18
April 29th, 2005 01:42 PM #5Originally Posted by KALAMPAG
Thanks for the advice sir. Nag area pa naman ako weekly.. laguna/batangas..
Critical pala eto... is it a must gawin replacement sa Honda Casa or kahit sa shop lng.. (i.e. - expresslube)?
- Oct 2004
- 132
April 29th, 2005 06:08 PM #6Originally Posted by scooby91
May 1st, 2005 01:36 AM #7
Kung common ang engine mo, the hoses can be found in almost any auto supply. I'm not sure if this is the case with Hondas since yung 4d56 kahit sa Palengke nakakita ako dati (Batangas area).
Pwede ito sa expresslube. Just remember that you have to drain everything out not just in the radiator. This can mean having to remove the coolant plugs on the engine block itself and the thermostat. Sumasara kasi ang thermostat when cold.
May 1st, 2005 11:37 AM #8
meron na yan sa banawe either Pemview, Multiline ,HRC, LVC.
Yung sa CR-V ko pinalitan lower radiator hose 350 bili ko sa Pemview.Same brand as the OEM na benta sa Casa (QD yata yun).
Nagtanong ako sa Honda QC nasa 950 daw yun.
May 30th, 2005 04:28 PM #9
tanong ko lang kung safe din ba gamitin yung transparent na radiator hose (yung may steel braided) for diesel engine particularly sa 2B engine ng land cruiser? nung weekend kasi nag tanong tanong ako kung magkano yung radiator hose sa binondo. sabi ng guy sa isang shop doon na pwede din daw yung transparent steel braided na hose (made in japan) for radiator use. gusto ko lang malaman kung tatagal ba talaga ito sa init ng diesel engine? nasa P100 per foot yung price nito.
thanks.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
