Results 1 to 9 of 9
    Apr 2005
    How much estimated cost to replace all "cooling hoses"?
    Wahts the working fluid in this system - tubig din?
    Had my civic'97 PM at Honda Alabang, guys said i need to replace hoses on next check-up.
    May 2004
    the quote 2 years ago to replace all the hoses is 4k at Honda Alabang. Medyo masakit, so kinalumutan ko muna. Up to now, okay pa naman. Your call.
    Btw, 99 Civic yung sa akin.
    Fluid in system is ideally a mix between distilled drinking water (distilled para walang solids) and ethelyne glycol based coolant. Mix 50/50.
    Radiator hoses cost only a hundred or so sa auto supply.
    Oct 2004
    Palitan mo na yan mga hoses bro as soon as possible. Sa kin tumagas na nung isang araw. I have a thread here also about hoses... heheh... si sir otep master yan..:-) Mahirap nang abutan ka between long drives...mabuti sa kin asa bahay na ko at d p tuluyan nagoverheat dahil lumabas na coolant ko.
    FYI. We have the same car.
    Apr 2005
    Quote Originally Posted by KALAMPAG
    Thanks for the advice sir. Nag area pa naman ako weekly.. laguna/batangas..
    Critical pala eto... is it a must gawin replacement sa Honda Casa or kahit sa shop lng.. (i.e. - expresslube)?
    Oct 2004
    Quote Originally Posted by scooby91
    Mahal definitely sa casa. Pero as sir otep says... sa manufacturer lang meron nung mga hoses with their "funny" shapes. Pero kung may alam ka na shop then good for you.
    Kung common ang engine mo, the hoses can be found in almost any auto supply. I'm not sure if this is the case with Hondas since yung 4d56 kahit sa Palengke nakakita ako dati (Batangas area).
    Pwede ito sa expresslube. Just remember that you have to drain everything out not just in the radiator. This can mean having to remove the coolant plugs on the engine block itself and the thermostat. Sumasara kasi ang thermostat when cold.
    meron na yan sa banawe either Pemview, Multiline ,HRC, LVC.
    Yung sa CR-V ko pinalitan lower radiator hose 350 bili ko sa Pemview.Same brand as the OEM na benta sa Casa (QD yata yun).
    Nagtanong ako sa Honda QC nasa 950 daw yun.
    tanong ko lang kung safe din ba gamitin yung transparent na radiator hose (yung may steel braided) for diesel engine particularly sa 2B engine ng land cruiser? nung weekend kasi nag tanong tanong ako kung magkano yung radiator hose sa binondo. sabi ng guy sa isang shop doon na pwede din daw yung transparent steel braided na hose (made in japan) for radiator use. gusto ko lang malaman kung tatagal ba talaga ito sa init ng diesel engine? nasa P100 per foot yung price nito.
    thanks.
Cooling Hoses
