Results 1 to 8 of 8
- Jun 2005
- 2
June 3rd, 2005 12:31 AM #1Nakabili ako ng radiator fan motor replacement para sa lancer 94, kaso di nag-fit yung original fan blades dahil malaki yung butas para maikabit yung fan blade sa shaft nng fan motor. May nagkasyang fan blade na pang honda pero iba yung angle nung fan blades. Hindi ba masisira yung fan motor kung i-reverse yung polarity nung wire para umikot sya na tama yung direksyon nung hangin?
June 3rd, 2005 12:35 PM #2
yung ibang fan motors pede, paikutin ng reverse direction ba kamo? tulad ng mod nila sa nissan vanette.
pero most yata d pede...you'll burn the motor.
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 3rd, 2005 01:05 PM #3better to just get the correct motor, pwede naman siguro ibalik yan right?
June 3rd, 2005 03:08 PM #4
may certain angle yata ng comm brushes para tama yung contact nya sa rotor electrodes. If ireverse mo polarity para mag reverse rotational direction nya, baka mabilis masira. As others mentioned, better kunin mo na yung tamang specs. = )
June 4th, 2005 11:46 PM #6
tignan mo yung carbon brush ng commutator kung perpendicular or centered sa shaft. if so then pwede kahit reverse direction. meron kasi yung naka-angle or off-center yung carbon brush, di pwede i-reverse.
- Jun 2005
- 2
June 6th, 2005 02:29 PM #7OK thanks. Ipapacheck ko na lang yung loob ng fan motor tapos pag di talaga u-ubra ipahahanap ko na lang ng tamang fan blades. Maraming salamat ulit sa mga input at advice n'yo : )
June 6th, 2005 07:15 PM #8
kung ako sayo , ibalik mo na lang yung binili mo at palitan ng tugma sa kotse mo,para alang kang sakit ulo , kung problema mo sa binilhan mo alng pareho , soli pera, hanap ka sa iba, ganyan kasi ang style sa mga surplus store pipilitin yun iba parts na di pwede, pra lang magkabenta, paminsan minsan use your yung consumer right para di umabuso yun mga mapagsamantalang surplus shop,(base sa experience ko).
i suppose, it's ok for empty nest syndrome owners who do not drive to farther-flung areas. ......
VinFast VF 3
