Results 21 to 28 of 28
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 3rd, 2005 08:15 PM #22Originally Posted by pitbullz
- Sep 2005
- 37
December 3rd, 2005 08:51 PM #23Originally Posted by rsnald
December 3rd, 2005 11:24 PM #24
Originally Posted by F1fireserpent
Coolant actually decreases cooling performance but it's a necessary evil due to the aforementioned benefits (raises boiling point, antifreeze, anticorrosive, lubricant, anti-cavitation). So if you use pure coolant you'll probably overheat.
December 4th, 2005 12:48 AM #25
ano po yung 50/50? if i understood it correctly.....ang coolant (na benta sa gasolinahan or auto supply) ay 100% coolant? (ethylene glycol na yun?)
di po ba: coolant (50%) + water (50%) = 100% liquid poured into the radiator?
Or, mayroon na bang pre-mixed (50+50) na benta ngayon?
IM experience, *50+50 (coolant + water) increases the boiling temp of the radiator water, thereby reducing overheating.
will altering that ratio (like 30% water + 70% coolant) harm the engine? or increase the boiling point? or is it not advisable? is it advisable to do this? is it advisable to use 100% coolant, para mas mataas ang boiling temp?
- Nov 2005
- 5
December 4th, 2005 06:27 PM #26pag nag lagay ka ng coolant (not plain water, coolant din po kasi ang water) sa bago mong sasakyan, may proteksyon na ang radiator mo sa corrosion. ang main ingredient po kasi ng coolant (yung may kulay) ay inhibited ethylene glycol, ito po yung anti-rust compound which is mixed 50/50 with water. ok na pong ilagay ito sa radiator kahit di nyo na haluan ng tubig, mas marami kayong tubig na ilalagay mas malaki ang chance na kalawangin ang radiator nyo, pag purong tubig lang sigurado pong kakalawangin ang radiator. pag luma na ang radiator at linagyan nyo ng coolant, manunuot po ang inhibited ethylene glycol sa kalawang, posible po na magka tagas ang radiator nyo. so sa una pa lang maglagay na po kayo ng coolant (50/50) para may proteksyon ang radiator nyo. wala rin pong mabubuhay na algae sa init ng makita, hindi po totoo na lulumutin ang cooling system nyo. yung purong ethylene glycol po ang ginagamit na coolant sa mga turbina.
- Nov 2005
- 5
December 4th, 2005 06:43 PM #27yung binibenta pong coolant sa market 50/50 mixture po ito ng inhibited ethylene glycol with water, meron din pong 70/30 mixture na may mas mataas na boiling point. colorless po ang purong ethylene glycol linalagyan lang po ito ng kulay para malamig sa mata.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
