Results 1 to 20 of 28
    Sep 2005
    what are the practical advantages of using radiator coolant over plain or distilled water? will using ordinary water easily destroy today's engines?
    I remember when I was still a kid (sigh) and we still had our tough Ford Fiera (the first AUV?), everytime we cross the stream before climbing a steep uphill to our farm, my father will just fill a bucket of water from the stream and pour it directly to the radiator...no overheating going up
    now pre-packaged commercial coolant is everywhere which we all know is not too environmentally friendly.
    Search po dami na po threads about that.
    Sep 2005
    Water cools the engine and commercial coolants protects your radiator from corrosion. If you use a commercial coolant, you also need to mix it with water. A commercial coolant mixed with water also increases the boiling point of water resulting to less pressure build up in the radiator.
    BTW, we only use water for our cars' radiator.
    Oct 2005
    Quote Originally Posted by russpogi
    MASAMA BA PAG MAY COOLANT?TNX..
    Sep 2005
    Quote Originally Posted by eurie
    Absolutely not! It's just an option you can put in your radiator to prevent rust and corrosion on your radiator and it also increases the boiling point of the water.
    Jan 2004
    sir eurie, hindi po masama. mas masama kapag walang coolant kasi plain tap water could cause corrosion (rust) to the water jackets of the engine block, at mas mababa ang boiling point kesa sa merong coolant (hence, coolant). sure, rust won't hurt the engine, but these deposit could block the passageway eventually, thus resulting to overheating...
    And most coolant is already pre-mix with water called 50/50, no need to mix it with water yourself.
    Tap water, mineral water, distilled water?
    Quote Originally Posted by ineedmorehp
    carbonated water? hehehehe.
    Sep 2004
    Quote Originally Posted by happy_gilmore
    meron ngayon flavored water baka mas refreshing para sa auto yun.
    it will work... especially if you have no other water to use.
    Aug 2005
    distilled water.
    using mineral water (or ground water) might cause eventual "scaling" inside the engine/radiator. This is mineral deposits left behind after the water have evaporated... something like salt left behind after you heat saltwater.
    Jun 2005
    magkakano naman kaya yun 50/50?
    nakakabara daw yun coolant sabi nila toto nga ba
    Sep 2004
    coolant itself will not clog your radiators. ang nakakabara ay yung mineral deposits kung tap water or mineral water ang gagamitin mo. The best to use when diluting coolant is distilled water. di rin ok kung pure water lang gagamitin mo.
    May 2004
    mas mabuti siguro yong coolant, kaya nga siguro inintroduce ito.
    Nov 2003
    coolant also lubricates the waterpump etc better than plain water.
    pag malaming panahon, walang kwenta water coolant. misnomer yung term na coolant. what the "coolant" actually does is to raise the heat capacity of water so that it boils at a slightly higher temp. pero para mangyari yan, malaking volume ng coolant ang kailangan mo, as in 1:1 ratio coolant:water or more. Yung anticorrosive effect naman is not really because of the coolant - which is either ethylene glycol or propylene glycol. Meron kasing anticorrosive additives yung coolant. Sa kin, mas mabuti pa kung makakabili kayo ng anticorrosive additive na pwede nyo ihalo sa radiator water. mas may pakinabang pa yun kesa sa coolant. Pero tama na dapat distilled water ang gamitin, wag mineral water, tap water, carbonated water or holy water
    Sep 2005
    Quote Originally Posted by rsnald
    Sir, bakit hindi bah pwedeng purong coolant ilagay diba anti rust sya? edi mas protection sya sa kalawang? Bakit pinahahaluhaan pa nag tubig Marami nagsasabi nakakasira kapag puro coolant n ilagay
    Mar 2005
    Quote Originally Posted by F1fireserpent
    Coolant actually decreases cooling performance but it's a necessary evil due to the aforementioned benefits (raises boiling point, antifreeze, anticorrosive, lubricant, anti-cavitation). So if you use pure coolant you'll probably overheat.
Radiator Coolant vs Plain Water
