Results 11 to 20 of 28
December 2nd, 2005 10:06 AM #11
magkakano naman kaya yun 50/50?
nakakabara daw yun coolant sabi nila toto nga ba
December 2nd, 2005 10:17 AM #13
coolant itself will not clog your radiators. ang nakakabara ay yung mineral deposits kung tap water or mineral water ang gagamitin mo. The best to use when diluting coolant is distilled water. di rin ok kung pure water lang gagamitin mo.
December 2nd, 2005 10:19 AM #14
Originally Posted by happy_gilmore
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 2nd, 2005 02:37 PM #17
pag malaming panahon, walang kwenta water coolant. misnomer yung term na coolant. what the "coolant" actually does is to raise the heat capacity of water so that it boils at a slightly higher temp. pero para mangyari yan, malaking volume ng coolant ang kailangan mo, as in 1:1 ratio coolant:water or more. Yung anticorrosive effect naman is not really because of the coolant - which is either ethylene glycol or propylene glycol. Meron kasing anticorrosive additives yung coolant. Sa kin, mas mabuti pa kung makakabili kayo ng anticorrosive additive na pwede nyo ihalo sa radiator water. mas may pakinabang pa yun kesa sa coolant. Pero tama na dapat distilled water ang gamitin, wag mineral water, tap water, carbonated water or holy water
December 2nd, 2005 03:06 PM #18
it will work... especially if you have no other water to use.
Toyota is my choice
- Aug 2005
- 2,063
December 3rd, 2005 04:03 PM #19may post na po na ganito.. search po dun sa search tab na keyword "coolant".. madami kang matutunan doon..
ito little tips!
Flush muna!
50% Distilled water + 50% collant!
ayan pwde nba?
December 3rd, 2005 06:31 PM #20
i was told that coolants encourages algae or lumot propagating in your cooling system. true or false?
magkano na nga ba now yun 50/50?
I have a digital gauge that measures, among other things, engine coolant temp. 90% of the time,...
