Results 1 to 20 of 20
    Aug 2015
    I noticed my car consume lots of water after a short drive. Halos ma-drain yung nasa reservoir ko, kahit tinakbo ko is around 6km lang. Galing na din akong Evangelista for overhaul ng radiator, pero same problem occurs. Kita ko naman walang leak sa radiator after nung overhaul, baka may naka-experience ng ganitong problem. Also, checked yung ilalim nung car, wala naman leak habang naka-park. I'm planning to go back to the shop tomorrow, pero baka may inputs yung mga expert dito sa tsikot.
    According pala dun sa nagkabit nung radiator kanina, okay naman yung pagkaconnect nung hose and walang leak ung reservoir ko. Hindi ko talaga alam pano nauubos yung tubig kung walang leak.
    Thank you mga sir
    Car: 2004 Honda City
    Oct 2015
    Maybe worn radiator cap gasket?
    Aug 2015
    Mukang okay pa naman yung radiator cap gasket (but I'm not an expert, so I cannot tell talaga haha), pero hoping na yun yung problem. Pagbalik ko sa shop bukas papalitan ko na din yung cap, sana maayos na yung problem. Thank you sir Wh1stl3r2 sa input
    Check your oil dipstick & oil filler cap. If you see mayo, coolant is mixing w/ oil....means the head gasket. Let's hope not.
    Aug 2015
    No luck mga sir, hindi ko napalitan yung radiator cap. Ganun pa din consumption ng water, pero dinala ko sa ibang shop and tinaas nila yung sasakyan and sinilip na walang leak sa ilalim. Baka daw Head Gasket, sabi naman dun sa isa baka thermostat. Kaya di ko muna pinagawa, medyo kapaan pa yung issue eh. Any other input sir?
    Thanks sir PMtravajante! I checked the dipstick and oil filler cap, normal naman sa tingin ko. I attached some pic for reference, if normal nga ba
    Attached Thumbnails Attached Thumbnails img_4863.jpg   img_4861.jpg   img_4856.jpg
    Feb 2009
    Take it to a shop that has a cooling system pressure tester. It should hold at least 10% of your radiator cap rati g for at least 15 minutes
    Nov 2007
    Congrats at nakita ang leak. Saang shop mo napagawa? May pressure tester sila?
    Aug 2015
    *JJB, sa talyer ko lang pinagawa nakita ko sa OLX Honda Specialist Auto Mechanic Home Service For Sale Philippines - Find New and Used Honda Specialist Auto Mechanic Home Service On OLX improvised pressure tester lang using air pump for bike. Pero compared sa mga una kong pinuntahan na shop, talagang binusisi nila para mahanap yung problema.
    May 2009
    Quote Originally Posted by cRane01 View Post
    actually meron ako ganyan. homemade lang....yung pinagpalitan ko na radiator cap, tinanggal ko yung spring tapos binutasan at nilagyan ko ng pito ng gulong worth P50 lamang. plus the silicone sealant. cheapy cheapy. pero it works. magfeed lang ako ng 10-12 psi of air from my compressor. nakita ko lang ito sa mga youtube mechanics. haha
    Apr 2017
    How much did it cost?
    Nov 2007
    Buti at nagawa ng former Honda mechanic!
    Jul 2017
    Hello. Pede po maki-sakay sa topic nyo? I think we have tge same problem. Bilis konsumo tubig. Echo 2001 po car namin. Worried ako baka internal leak or blown gasket. May mga taga marikina po ba sa inyo?
    Sent from my SM-N7502 using Tsikot Forums mobile app
    Quote Originally Posted by marc.alan View Post
    1. perished radiator cap.
    2. defective radiator fan.
    3. dirty, clogged radiator.
    4. radiator leak.
    5. internal leak in the engine. but i'd rule out the above first, before tearing into the engine. symptoms of internal leak include white smoke in the exhaust, among others.
    good luck.
    Jul 2017
    Same problem here. What I did to resolve is replace the radiator cap kasi worn out na gasket and water reservoir cap kasi maluwag din. Hope this helps.
Radiator consume lots of water after short drive
