Drain your radiator loop, flush with plain water, then fill with flush. Run your engine as prescribed in the instructions and then flush again.
Refill with coolant (30% concentrate/70% water) or pre-mix.
Distilled water is a myth considering how easily contaminated it becomes when it touches the surface of your radiator an engine. Clean filtered is all you really need.
