Results 11 to 17 of 17
- Mar 2007
- 79
December 7th, 2013 06:28 PM #11
December 7th, 2013 06:55 PM #12
Denso sells oem rad caps coolmate pasong tamo
Sent from my iPhone using Tsikot Car Forums
- Aug 2005
- 553
December 8th, 2013 08:31 PM #13The function of the reservoir are 2 fold. First it is to store surplus coolant to last the duration between maintenance cycles. And second it is a surge tank that holds coolant that has overflowed from the radiator under high pressure conditions.
When pressure normalizes, assuming it is a sealed system, the coolant will return back into the radiator.
But if you are revving your engine and you have the cap off, and the radiator is boiling or gushing out from the filler neck, then you may have cylinder head issues that you may want to check up on especially if you're overheating.
December 31st, 2013 12:02 PM #14
up ko lang, circuit brand na nabili ko 2 weeks lang deformed na agad yong gasket nya hanap muna ako ng bago today baka meron pang bukas na auto supply, happy new year to all tsikoters
- 54,293
December 31st, 2013 12:07 PM #15
- Aug 2005
- 553
- Apr 2009
- 429
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
