Results 1 to 3 of 3
January 5th, 2014 12:35 PM #1
May stain of rust brown ang water ng radiator ko and it still not been cleaned and repaired since. Anyone undergoes cleaning or replacement or repairs done. Magkano na ang prevailing rates (PHP) for budgetary purpose nowadays? TIA
- Oct 2013
- 1,181
January 5th, 2014 01:34 PM #2Tingnan mo capacity ng radiator mo, bili ka ng distilled water like wilkins or absolute, then drain mo at palitan ng distilled, run it without the cap for about 10 minutes. Drain then refill mo ng pre-mixed or yung coolant na hinahaluan ng distilled water from your casa.
Read the manual kung paano gawin mga yan.
- Aug 2005
- 553
January 6th, 2014 03:57 PM #3Drain your radiator loop, flush with plain water, then fill with flush. Run your engine as prescribed in the instructions and then flush again.
Refill with coolant (30% concentrate/70% water) or pre-mix.
Distilled water is a myth considering how easily contaminated it becomes when it touches the surface of your radiator an engine. Clean filtered is all you really need.
