Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Oct 2007
    Hey mga bro patulong naman, mag papa drain kasi ako ng radiator this week, I just want to know kung ilang "coolant at distilled wate"r ba ang kakailananin ko? may nakita ako sa ACE na Prestone Coolant 1Liter - 313 petot, Ok na ba ang 1liter? kasi sa mga nabasa ko dapat 50/50 dapat ang mixture. ibig sabihin ba nito kung 3 liters ang distilled water 3 liters din ang coolant? patulong naman po. naguguluhan na ako...di ko alam kasi kung gano karami bibilin kong coolant at distilled water. thanks
    May 2007
    Quote Originally Posted by lancer_89 View Post
    Correct: 50% coolant/ 50% distilled water. How many liters? Depende sa laki ng radiator mo.
    Dec 2007
    akala ko ung coolant basta ibuhos na lang dun sa plastic na lalagyan nya sa tabi nung radiator, ok na. may mixture percentage pa pala
    get the premixed na so you would not worry about the 50:50 ratio. imho, yung prestone is premixed na so buhos na lang yun.
    Jan 2008
    ilang beses po nagpapa-drain o nagpapalit ng radiator coolant sa loob ng isang taon?
    Dec 2007
    Quote Originally Posted by 1D4LV View Post
    ahh i see, thats good to know. thanks!
    i'm still guilty of using regular tap water rather than distilled water. ung mga binibili ko kasi wilkins para sa gatas ng baby ko, baka magalit si misis pag sa tsikot ko nilagay hahaha peace
    Quote Originally Posted by jayemkay View Post
    Get the 5 or 6 liter container of Absolute distilled drinking water, it’s cheaper.
    TS, if you will use the concentrate, pour a liter or 500ml coolant then followed by the same volume of distilled water hanggang mapuno. prepare at least 2 liters of concentrated coolant at least. sobra na yun.
    Jun 2004
    pag premixed ba pwede ilagay dun sa container ng coolant? kasi sa sasakyan namin nasa minimum level na yun coolant resevoir. eh may stock dito sa bahay ng prestone.
    mejo nalilito din ako
    Quote Originally Posted by sarceangel View Post
    it should be at least once a year.
    the answer is yes.
    Oct 2007
    maraming salamat sa mga replies. to be safe i'll buy a 3Liter Prestone Concentrate coolant and (2) 5Liter distilled water. mas maganda na siguro sobra kesa magkulang. nasira kasi waterpump ko kaya naubos lahat ng coolant, kaya eto no choice kelangan pagawa ng water pump, drain and refill ng bagong coolant.... Gastos na naman.
    Jan 2008
    sir mas cheaper ang SM Bonus distilled water
    May 2007
    Quote Originally Posted by iho250 View Post
    Distilled water are same. Just make sure not a tap water what you buying.
    Quote Originally Posted by v6dreamer View Post
    distilled, not tap. not mineral, not ionized, not vitamin enriched. hehehehe.
    Aug 2006
    Gatorade propel kaya na may halong extra Joss parang coolant ng prestome dilaw hehehehe ingat lang sa coolant too much can destroy water pump not all coolants are the same pero ung prestone sure na un ready to use
    Aug 2008
    mga sirs. dagdag question po. i recently bought Prestone 1liter coolant. it says in the label as "concentrate", does it mean kelangan ko i-dilute ito w/ distilled water before i put it in the reservoir? i see diluting ratio instructions din kasi sa back label nya. are there Prestone concentrate & Prestone premixed , or iisa lang po tlgang klase ito? tnx po.
    Dec 2007
    Quote Originally Posted by hakkinen View Post
    Just follow those instructions on the label, you'll be all right...
    Aug 2007
    Mga Sir, ibig sabihin bawal pala lagyan ng tap water ang 'coolant reservoir', dapat coolant talaga like Prestone ready mix?
    Quote Originally Posted by Zinc View Post
    for added info about coolants, search ka lang sir daming topic tungkol dito.
    di naman bawal ang tap or galing sa balon or known as mineral water, kaya lang malakas siya maka kalawang kaya mas maige ang distilled water. marami namang medyo murang distilled drinking water like sm bonus, absolute or yung sikat na wilkins. best shot siya kung ihahalo sa anti boil coolant.
    Aug 2007
    Thanks a lot sa info Sir, definitely will follow the advise.
Radiatior Coolant Question
