Originally Posted by
niky
Leak yun. Check your hoses and your radiator for holes, if you don't find any at first, doesn't mean they're not there. Hard and brittle hoses often leak at the ends when the engine is hot. Also check for leaks under the water pump.
If you can't find anything, try leaving the radiator cap off and running your engine. If you see bubbles or surging when you rev the engine (once it's hot), could be a gasket problem... which is expen$ive.
Pero it depends pa rin. Pag mainit at matrapik, nag-e-evaporate naman talaga ang water paunti-unti. If the level goes down slowly over a month, it's probably okay.
