Results 1 to 8 of 8
    Jan 2004
    just had my radiator checked for leaks and ok naman lahat. will ask my mechanic about the aux fans.
    Jan 2008
    well you may also opt to check your compressor clutch coil if all items above is checked OK.. it will not engage if the magnetic coil clutch is already busted..also possible you have a loose wiring connection to the compressor clutch
    maraming aircon shops libre check-up ... they will connect thier pressure gauge/s to determine if your compressor is doing its job properly and/or the system lacks freon
    Jan 2004
    thanks guys. at least i have an idea what to look for
question po about aircon
