Results 1 to 13 of 13
    Feb 2015
    Mga idol, tanong ko lang. Next week kasi, pupunta kami ng Pangasinan so long drive siya, ask ko lang kung ok lang ba ibiyahe ko yung sasakyan ng walang thermostat at thermoswitch? Bale yung mga fans niya, naka-rekta. Ano kaya yung possible problems na pwede kong ma-encounter? Thanks is advance po sa makakasagot.
    Oct 2013
    Pwede kang mag overheat sa panahon ngayun. Dala ka lang tubig.
    Jul 2011
    ang gamitin mo wilkins distilled water, para kahit papaano e wag ng malagyan pa ng mineral deposits ang cooling system mo.
    May 2010
    Nakarekta din yung fans ko sir pero never had issues even on long trips. Pero for peace of mind I always have spare hoses, fuses and relays. Medyo OC pero better safe than sorry.
    Have a safe trip sir!
    Feb 2009
    Problems you may encounter not now but in the future include carbon build up, excessive wear in the engine and clogged catalytic converter. Problems you will encounter during the trip include low fuel efficiency, reduced power and high exhaust emissions, premature and possible breakdown of your PART TIME electric cooling fan motor
    Madalas ka lang masisiraan at magpapalit ng mga fan motors para sa radiator at condenser. Ayos lang kung walang thermostat valve, basta may thermo switch. Mainam pa rin ang meron thermostat valve.
    Sent from my Starmobile UP+ using Tapatalk
    Oct 2009
    sa akin may switch para sa thermo switch.pag naramdaman ko sobrang init i switch ko lang sa rekta pag naka trapik pero pag malamig panahon automatic kona ilalagay..
    pag naka rekta kasi ung fan mo.delikado pag nasunog fan motor mo..sigurado ititirik ka nyan.
    Feb 2015
    Hmmm, based doon sa mga nabanggit niyo, hindi nga advisable na ibiyahe ng nakarekta ang fan, baka masira lang o mas malala, bumigay yung relay ko. nakaka-dalawang relay na ako pero 2nd hand lang naman. Since may time pa naman, baka pa-convert ko muna sa switch mode o sana, ma-restore ko na ung thermoswitch ko para di na hassle.
    Ano po ba ride nyo StarLord?
    Feb 2015
    Quote Originally Posted by rodetor View Post
    Sorry. Honda Accord 2000
    * StarLord, your ride is a Honda Accord 2000 pala. Whether it is an A/T or M/T, better put back the thermo-switch and thermostat valve when your able. For sure, you have some reason why un-install those two component parts in your cooling system.
    *StarLord, if you can't install back both parts, kahit yung thermo-switch lang muna maibalik mo. Thermo-switch is a sensor to your cooling system which automatically turn off/on the fan motor of your radiator in a certain temperature. Running at high speed in an expressway or highways, with thermo-switch, your fan motors will not turn on due to malamig pa coolant mo dahil napapalamig ng hangin sa pagtakbo mo. Without thermo-switch, napapalamig na ng hangin sa bilis ng takbo mo, andar ng andar pa rin fan motor para sa radiator. Dyan ka madalas magpapalit ng fan motor at relays.
    Jul 2003
    there are two thermoswitch installed. make sure both are good. they are rated differently, so do not interchange them. anyway, you will know if you have the wrong thermoswitch, the connector will not fit properly.
Question lang po..
