Results 1 to 7 of 7
    Apr 2006
    Hi guys, what could be the culprit causing the creeking noise when the aircon is on? thanks a lot
    Quote Originally Posted by rianne809 View Post
    Saan nyo po naririnig ang tunog?
    Apr 2006
    Hi, ive checked it this morning and i found out that the cause of the noise when i open the AC is that the motor on the compressor (actuator/clutch i think) is not rotating or rotates very slow and hard which makes the AC belt creeks
    mam, check po ninyo ang tension ng mga belts. one possible problem ng squeaking sound ng aircon yan. o kaya, lumusong ba kayo sa baha at gaano kalalim? kasi pag po basa ang pulley ng compressor, possible na nag-slip ang belt ninyo at hindi na kumakapit sa pulley.
    Stucked up na clutch mo, palitin na bearing. Parepair mo na aircon baka maagapan pa compressor..
    Apr 2006
    Thanks a lot for the replies, my brother also told me that the compressor bearing needs replacement.
    Oct 2008
    magnetic clutch yan sir
Creeking noise when I turnon the AC
