Results 1 to 7 of 7
- Apr 2006
- 8
October 15th, 2009 05:08 PM #1Hi guys, what could be the culprit causing the creeking noise when the aircon is on? thanks a lot
- 34
- Apr 2006
- 8
October 16th, 2009 10:52 AM #3Hi, ive checked it this morning and i found out that the cause of the noise when i open the AC is that the motor on the compressor (actuator/clutch i think) is not rotating or rotates very slow and hard which makes the AC belt creeks
October 16th, 2009 11:00 AM #4
mam, check po ninyo ang tension ng mga belts. one possible problem ng squeaking sound ng aircon yan. o kaya, lumusong ba kayo sa baha at gaano kalalim? kasi pag po basa ang pulley ng compressor, possible na nag-slip ang belt ninyo at hindi na kumakapit sa pulley.
October 16th, 2009 11:00 AM #5
- Apr 2006
- 8
October 16th, 2009 02:07 PM #6Thanks a lot for the replies, my brother also told me that the compressor bearing needs replacement.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
