Results 1 to 6 of 6
    Nov 2004
    Hi Guys,
    Just yesterday, the two aux fans (big and small condenser) ng pajero ko 4D56 stopped working. I tested the fans putting direct 12V DC ok sya. So definitely the fans are ok.
    I checked all the fuse doon sa fuse box sa engine bay beside the battery but wala namang busted. Any ideas alin pa kaya ang pwede kong i-check?
    Thanks!
    I had a similar problem... check the control relay that turns the fans on/off. It would probably be in need of replacing.
    Nov 2004
    Ghosthunter, I appreciate your quick response. Saan banda ko makikita ito? How much is it?
    thanks!
    Quote Originally Posted by the_possessed View Post
    thanks!
    It should be in the engine bay. Look for a black box with some labels on the top.
    Nov 2004
    Thank you! I assume this is the same box that has fuses right? I'll check again tomorrow apparently the labels are gone
    Nov 2004
    GhostHunter, you're right the relay is busted :D any idea how much is it and where to buy?
Pajero Aux Fan troubleshooting
