Results 1 to 10 of 20
- 350
July 26th, 2005 02:31 PM #1good day sa inyong lahat. Nagkaproblema kasi aircon ng local pajero GenII ko. Pinacheck ko ang hindi umaandar yung main auxillary fan,( the one behind the front grill ). Nung kinalog umandar naman, then pinaoff ang aircon tapos on ulit, ayun ayaw nanaman umandar nung fan. Sira na raw yung fan motor needs to be replaced and abutin daw ng 6thousand. Mahal daw talaga yung main fan ng pajero compared to other small cars.
May nakapagpalit na ba sa inyo ng ganitong fan or encountered same problems. Sabi pwde rin daw pahinang/parepair lang yung motor pero baka hindi rin tumagal. Baka may mabigay kayong tip, thanks.
July 26th, 2005 02:38 PM #2
try checking kay mang mario.. makakatipid ka dun big time with quality work
- Feb 2005
- 10
July 26th, 2005 04:47 PM #4Try spraying electronic grade contact cleaner the inside of the motor thru the drain vent. But you need to dismantle the fan first. You can also buy a surplus * P850. YOu must also check that the 2nd aux fan is also working.
July 26th, 2005 06:21 PM #5
if all else fails, I'm absolutely sure that you can find other fans that'll fit... pajero pa...
July 27th, 2005 08:36 AM #6
ako nasira na din yan, tama yung quote sa iyo, basta orig. sakit daw ng pajero yan. if i were u, go with the orig na if u plan on keeping ur paj for a long time. had bad experiences with surplus n other repair. d tatagal. bettr off with buying new.
July 27th, 2005 09:02 AM #7
Yup same here. I had mine replaced with a much cheaper brand but it didnt last that long. It would be better to use genuine mitsubishi parts to get your moneys worth. I had mine quoted for 11K pesos for general overhaul and cleaning of the whole aircon unit sa kasa.
July 27th, 2005 10:37 AM #8
Had mine repaired by Mang Mario. Around Php 300.00 or so if I'm not mistaken.
Lancer ni odell diyan din inayos ang fan nung nag-fail.
- 350
July 27th, 2005 06:18 PM #10o nga david. Salamat sa reply bossing otep, galing ako kanina kay mario and hindi na nga pwde marepair yung motor kasi manipis na raw yung mga grooves. I decided to go with the replacement fan. They charged me 1800 for the part and labor na.
Less than half the price ng original kaya try ko na rin, hopefully tumagal.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
