Results 1 to 10 of 10
    May 2007
    Tanong Lang Po..
    Kung Di Gumagana Ang Temp. Gauge Tapos Overheat Na Pala. Ano Po Ang Mangyayari. Ano Po Unang Mararamdaman Ng Driver Sa Sasakyan Kung Overheat Na? Kusa Po Bang Hihinto Na Lang Yung Sasakyan? After Overheat Aandar Pa Kaya? Ano Possible Na Masisira? Sa Ngayon Po Kasi Di Gumagana Temp Gauge Ko (2c-turbo Engine). San Po Kaya Puwede Bumili Nag Hiwalay Na Temp Gauge Lang? Yung Medyo Maganda Naman Itsura Kasi Erratic Na Temp Gauge Ko. Minsan Gumagana Minsan Hindi. Maraming Salamat Po!
    May 2007
    Change your Thermostatic control and water temp sensor ( check also the sensor connector) also clean your radiator. Add coolant and distilled water, 50/50 mixture.
    Jun 2006
    tama si v6dreamer, whag na iyun arte na pipili pa ng magandang gauge, kung okay pa iyun luma pagtiyagaan, malamang hindi doon ang sira...
    isang bagay lang mangyayari pag nag overheat sasakyan mo, titirik... kapag tumirik ma-tow pa ng mga buwaya at gastos ka ng mahigit isang libo, maliban doon may posibilidad pa kumatok ang makina kung pipilitin patakbohin ang overheat na sasakyan... gastos mo naman doon aabot ng hindi kukulang ng 20thousand plus...
    bago mo paandarin sasakyan mo, buksan mo hood at check mo iyun radiator kung may tubig... oki...
    May 2007
    Tnx. Ilang Months Po Ba Dapat Palitan Yung Coolant? Nilinis Kasi Yung Needle Nung Sa Temp Gauge Tapos Umandar For 1 Month, Ngayon Paminsan Minsan Na Lang. Di Bale Po Babalik Ko Sa Electrical, Pacheck Ko Na Lang Yung Advise Nyo.
    Jun 2006
    Quote Originally Posted by crusader View Post
    coolant replace after 2 years
    Nov 2003
    replace the sending unit imo. yun yung most likely na bumigay.
    May 2007
    I changed my coolant every summer to avoid rush contamination in the internal cooling and heating system. At saka mura lang naman ang coolant. Why settle for more?
    Nov 2003
    every year is a bit much pero more often is better than waiting till something happens.
    May 2007
    mga sir nung dinala ko po sa rey electrical 2x na ang ginagawa nila spray with wd-40 yung sa temp gauge needle tapos gagana lang yun ng 1 month tapos binalik ko uli pareho din almost 1 month gagana, minsan bigla na lang babagsak..tingin nyo po sira na po talaga? suggest nila na magpalagay na lang ako ng mechanical gauge cost 1200, effective kaya yun? ask ako sa toyota, it would cost me almost 8k parts and labor w/ brand new instrument panel. mga fellows nagkaroon na ba kayo ng ganitong problem? ano po ginawa nyo? ano po kaya suggestion nyo? hiwalay na temp gauge or sa toyota? plan ko na kasi pagawa na lang sa toyota pagdating dec kapag wala nangyari. may alam po kayo shop na mabibilhan nung parts na ganito? mga shop owners may pumunta na ba sa inyo na pareho problem ko, ano po suggestion nyo? tnx sa lahat ng replies! GODSPEED...
    May 2007
    Sir V6 Dreamer!! Na Locate Ko Na Po Kung San Yung Water Temp Sensor>>>san Po Ba Banda Yung Thermostatic Control? Sa May Compressor Po Ba Yun? May Connection Din Ba Sya Sa Temp Gauge?
Overheat/temp Gauge Not Working
