Results 1 to 6 of 6
    Jul 2012
    normal lang po b na parang naglalangis ung rubber hose ng a/c coming from compressor going to condenser, ito yata ung high pressure coz H nakalagay sa aluminum fitting? pansin ko po na khit punasan ko e oily pa rin after using the car. is this ok or sign of leakage but a/c is cold
    It's a sign that the oil inside your ac system is leaking out eventually the coldness of your ac system will start to degrade. Better have it replaced and make sure your system is properly vacuumed and flushed.
    Jun 2011
    tama po si sir diesel... may leak na po yung hose nyo... check nyo yung hose at fittings.... lagyan nyo lang ng sabon makikita nyo na kung may leak...
    Jul 2012
    just checked w/ soap the hose and fittings, wala nmng leak, pansin ko lang na may slight sugat ung hose na nagooily, may oil or lubricant po ba ang hoses ng a/c w/c serves as insulation? baka kc ung inside ng hose ang nagleleak ng oil
    Quote Originally Posted by ahlecks View Post
    High pressure ang ac system pwede kasing di kita sa sabon at bula ang leak pero telling signs na ng leak yang oil sa ac hose. ipacheck mo na sa mga ac shops bago pa pasukan ng moisture sa loob at mas lumala problema mo mura lang naman yan.
    Jul 2012
    ok tnx po sa inputs mga sir. pacheck ko n lng s shop.
oily a/c hose
