What is the possible cause of this? the car still ok.
It is a sign of impending engine failure. Perhaps cylinder head gasket leakage or a crack on your cylinder head.
Go to your suking shop ASAP para ma-top overhaul na yang makina mo baka lumala pa. As Benji_DCP has mentioned, swerte mo kung gasket lang ang sira pero kung cracked cylinder head yan medyo mahal na.
kung automatic car ninyo, pwede din manggaling sa tubing inside the radiator papuntang transmission.
may overheat ba sir?
kung meron, cylinder head may problema.
i dont know its true.. I think.. busted cylinder head gasket kaya ng mix yung langis at water and can be seen inside ng radiator. busted could be possible cause of overheating.
most likely its a worn-out cylinder head gasket or your engine oil cooler is leaking....
btw what's your ride?
It's a (XE 1.3 2E Engine, Manual). But still no water on the OIL. Only the radiator w/ oil.Originally Posted by marlon22701
Baka naman coolant lang yan.. ang akala mo lang ay oil..... Yung ibang coolant kasi ay parang may halong oil pag hinawakan mo.
white smoke could also mean a headgasket failure, try to check it out
