Results 1 to 10 of 20
- Sep 2013
- 153
December 17th, 2013 06:41 PM #1Hello,
Ask ko lang, anung possibleng reason kung bakit ung radiator ko nagbabawas ng tubig pero ung reservoir hindi. Di ba dapat kapag nagbawas ung radiator, kukuha siya dun sa reservoir to compensate ung lost dun sa radiator? may connection ba to sa radiator cap? Kapag binuksan ko ung radiator cap parang may pressure na lalabas.
May mali ba sa napansin ko?
December 18th, 2013 10:59 AM #3
yup, check mo muna or replace the rad cap.
kung ganun pa din, there is a leak somewhere....
December 18th, 2013 11:09 AM #4
December 18th, 2013 12:34 PM #5
And if you change your radiator cap, go for OEM or a known brand like Denso. Don't go for the cheap ones (i.e. Circuit).
- Oct 2009
- 2,271
December 19th, 2013 04:19 PM #6bili ka sa surplusan kaysa sa lokal na nabibili sa mga auto supply.. may makukuha ka orig na surplus..pili kana lang..150 lang kuha ko..
- Sep 2013
- 153
December 19th, 2013 07:57 PM #7
- Sep 2011
- 37
January 5th, 2014 11:50 AM #8
- Aug 2005
- 553
January 6th, 2014 03:52 PM #9Supposing you have no leaks or breaks in your cylinder head gasket, any water that goes into you reservoir should in theory be drawn back into your radiator.
January 6th, 2014 04:11 PM #10
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
