Results 1 to 20 of 24
    May 2012
    Good evening mga sir. Possibleng may leak daw sa evaporator yung 2006 vios namin. According sa mga nabasa ko, ok na daw pamalit yung mga aftermarket evaporator, kahit anong class, as long as hindi yung locally made. Yung iba naman sabi mag-oem na kung kaya ng budget.
    Questions:
    1. Gaano ba kalaki ang difference ng oem vs imported aftermarket evaporator in terms of tibay at cooling effect?
    2. Any idea sa estimated price ng oem? Meron ba sa banawe nito or available lang sa denso kapag dun nagpagawa?
    3. Pareho lang ba kapag sinabing oem at laminated? replacement at aftermarket? (Paki-clear kasi nalilito ako)
    4. Quote kasi sakin 8.5k all in, laminated (note: tanggal dash). May naka-try na kaya na bumili na lang sa labas ng evap then pakabit sa shop para cost lang ng aircon cleaning(2.5-3k)?
    Sana may makasagot. Marami na ko nabasa dito pero wala kasi ako makita tungkol sa oem evaporator.
    Nov 2007
    1.ala masyado diff..maliban kung hindi marunong ang titingin..size,coolingfins at ang space nito.
    2.meron mga pwesto sa banawe.
    3.hinde..oem orig parts..ibig sabihin stock..laminated isang klase ng coil..exp sa ibang unit meron din tinatawag serpentineo di kaya yung fabricated.
    4.pm kita.
    Aug 2005
    Will change to after market evaporator.
    May 2012
    Ito sir sa 2003 altis mga year ago
    Sa denso q ave
    Evap 9,236
    Exp valve 2,250
    Drier 1,650
    Labor cost 2,500
    Dont know kung parehas sa vios pero palagay ko malapit
    May 2012
    Quote Originally Posted by SiPS View Post
    Questions:
    Mura na ung 8.5k sir kumpara sa denso all in all sa denso mga 19k palit evaporator drier and expansion valve. Buti ung akin noon ok pa evaporator askmo din kung pwede lagyan ng cabin filter ung akin pinalagyan ko
    Aug 2005
    As long as they are both warranted there shouldn't be much difference.
    Tubing, fin pitches, and all material gauges remaining the same of course.
    when my innova's rear evaporator sprung a leak, i initially asked for aftermarket, because it was cheaper. alas! it did not fit the plastic frame. i had to buy the OEM..
    Jul 2012
    on our 06 vios, inabot ng 12k. palit oem evap, freon, oil, yung fitting na nakadikit sa evap, drier, etc.. etc.. labor.. labor..
    May 2012
    Quote Originally Posted by enzo6k View Post
    Saan yan sir sobra pala talaga mahal sa denso he he.
Oem evaporator vs aftermarket evaporator
