Results 1 to 10 of 10
    Jan 2009
    Hi po,
    I badly some need expert advice.
    Almost 2 months din po kasi di nagamit ung car ko at nung gagamitin ko na uli, i have noticed na wala na lamig ung aircon. Then i decided to bring it to the aircon mechanic for inspection and found-out na wala na refrigerant ung system. I decided na pakarga ko na muna ulit since may napaka importante lakad ako during that time and plan to bring it again na lang pagka may time na. Then instantly bumalik sa dating lamig without problem so far.
    But after using the car and turned off the engine, a few hours later i saw white some coming out from aircon vents. And tried to observed, it is odorless and from evaporator. Then decided to turned on the aircon fan to blow it away and then turned on the ac. Nawala ung odorless white smoke and ok naman ung lamig ng aircon. Then after driving, ganon na naman ung result. Pero ok naman ung lamig so far and no electrical failure found.
    Ano kaya possible na problem? And one more thing na it bothers me most, it is possiby harmful and affect human health?
    Many thanks in-advance po..
    Aug 2008
    the oderless white smoke that is coming from your vent is a sure sign of a freon leak ,most probably from the evaporator, it can be harmful if you breath with this everyday
    mist ata yan. di smoke. nag tutubig ba sa may vent?
    Yup...ang alam ko freon leak yang white smoke na yan...if ever lumabas sya ulit, off nalang yung a/c kasi masama sa health yan kahit wala naman syang amoy...Same sa mga household and industrial aircon na may white smoke na lumalabas...
    Freon leak na yan boss. Pa--check mo ulit. Last time ganyan nangyari sa akin at may tama evaporator. Kapg di kaya sa hinang, yun ang masakit, palit evaporator ka na tapos freon bibili ka ulit.
    Jan 2008
    may konting amoy yan refrigerant... masama na malanghap yan nakakahilo
Odorless white smoke from aircon vents
