Results 11 to 20 of 29
April 11th, 2015 09:26 PM #11
April 11th, 2015 09:44 PM #12
Either the cooling/auxiliary fan ain't working or radiator is clogged up.
April 11th, 2015 10:09 PM #13
- Apr 2015
- 140
April 11th, 2015 10:24 PM #14Possible din na may tagas radiator mo sir. O kaya radiator cap is already faulty. Preliminaries first. Figers crossed.
- Nov 2014
- 87
April 11th, 2015 10:36 PM #15Nangyari yan the other day sa brother ng officemate ko. Pina overhaul radiator pero overheat/umaapaw pa din reservoir. Radiator cap lang pala problem
April 11th, 2015 11:12 PM #17
Replace Thermostat
ganyan di naexperience ko sa honda city
Replace Thermostat
- Apr 2015
- 140
April 12th, 2015 12:12 AM #18
- Mar 2014
- 901
April 12th, 2015 12:27 AM #19Good idea. If there is white smoke emits in your exhaust/muffler when the engine runs. Coolant/water from your cooling system enters your engine. A crack in your cylinder head gasket will be the culprit. If no white smoke emits, have your thermostat valve checked if stuck up by coolant/water corrosion.
Sent from my Starmobile UP+ using Tapatalk
April 12th, 2015 12:27 PM #20
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
