Results 11 to 20 of 57
- Mar 2014
- 901
July 9th, 2015 07:38 AM #11Kapag casual city driving, di ka nag-ooverheat. Kapag long drive, natural high speed takbo mo sa expressway, dun lang nataas temp gauge.
Sent from my UP+ using Tapatalk
- Mar 2014
- 901
July 9th, 2015 12:05 PM #12Kapag nataas temp gauge mo sa high speed driving, medyo clogged na o marumi luob ng radiator mo. Replace coolant/water in your cooling system. Kung hindi nare-solve sa pagpalit coolant/water sa pagtaas ng temp. It's either replace or overhaul your radiator.
July 9th, 2015 01:54 PM #13
check mo din thermostat mo bago ka palit rad. iyan din kasi symptoms ng damaged thermostats
tsaka sa experience ko kapag may butas na rad ko, maski city driving lang tumataas na ang temp ng cooling system ng sasakyan. so hingi ka ng 2nd opinion bago mo palitan raditator mo bro
- Jul 2012
- 329
July 9th, 2015 02:46 PM #14nakita ko po yung rad nung pinagawa ko aircon.. nung hinanap leak ng freon sa condenser nakita.. dun ko lang nalaman na may ngyari pala collision sa harap.. tinamaan yung condenser.. nung inalis nakita rin na may tama radiator. simula nung nagawa aircon eh nagsimula na rin nag over heat yung oto.. hindi pa nmn umabot sa point na umusok kasi pag umilaw na yung indicator eh tinatabi ko na agad at pinapalamig.. tapos ok na.
- Oct 2009
- 2,271
July 9th, 2015 03:15 PM #15wag kana bumili ng taiwan..
bili ka nalang surplus orig.basta pumili kana lang ng medyo sariwa pa.angtaiwan kasi madaling ma bend ung plastic sa ibabaw .madaling mabitak,after 1 or two years sira na..
- Jul 2012
- 329
July 10th, 2015 08:46 AM #17
Na flush na ba radiator mo? Daming radiator chemical flush na available.
Also water pump working? Usually these fail especially on older vehicles. You can see the water will swirl if the water pump is running.
Some cars require water pump replacement every several years. Nasa maintenance schedule.
- Mar 2014
- 901
July 10th, 2015 09:25 PM #18
- Jul 2012
- 329
July 14th, 2015 12:57 AM #19sir may alam kb magandang brand ng replacement na hindi masakit sa bulsa at hindi ikagagalit ni mrs?
- Jul 2012
- 329
July 17th, 2015 08:56 PM #20mga sir eto po pinag pipilian ko:
taiwan made - plastic radiator 3.5k LVC Auto Supply sa banawe with warranty
malaysia made - aluminum 4.6k Grand Sucat Auto Parts sa sucat no warranty
local made - plastic 4.7k Alabang Auto Parts sa alabang with warranty
taga binan laguna po ako. i was planning to buy from banawe kasi mura pero layo. nung nagtanong ako sa alabang parts meron sila local made tapos bigyan daw ako warranty - mas maayos kausap, madalas na rin ako bumibili ng auto parts sa kanila. yung sa sucat nmn nung ni ask ko kung may warranty sabi sakin hindi raw kailangan ng warranty ang radiator.
balak ko po ipakabit rad kay mel
anu po ma suggest nyo dun sa tatlo?
If that's the case, then it isn't cheap. More like a headache down the road, kahit pang coding...
2021 Nissan Leaf
