Results 1 to 18 of 18
    Feb 2006
    hi there,
    my 1994 Civic's radiator has a leak in the top side (area where the cap is). a car shop recommended to have it converted to the traditional steel (or whatever that brown colored metal is, similar to the older cars). since buying a new radiator will be too expensive
    i wanted to ask....
    1. it is a common practice to convert the top portion from plastic to steel? instead of buying new radiator?
    2. they quoted my P2,500. is that reasonable?
    appreciate any comments!
    thanks
    Please search, madami na po topics about this...
    Short answer for you though is to bring that radiator to DENSO (or PM Zeagle here) and have them replace the top with an ORIGINAL DENSO top as well.
    Feb 2006
    Quote Originally Posted by theveed
    Thanks theveed,
    i tried a search on "radiator conversion" and "radiator convert" but nothing came out...i will refine my search question....
    anyway, thanks for the help, now i know what to do.......
    cheers!
    you can also try looking into buying surplus parts.
    price starts at P2,500 nga for a brand new all-copper radiator.
    i got mine for my lancer at banaue some two years ago.
    Nov 2003
    for a little bit more you can get a brand new evercool unit
    Aug 2003
    Quote Originally Posted by speedyfix
    san po ba mabibili ang evercool? magkano po kaya para sa crv 2000 model
    thanks
    Like theveed said, drop by any Denso shop, they repair plastic radiators. Zeagle's is in Makati area, there's also one in Banawe.
    Aug 2005
    wow! i never knew i can save up money just to repair my stock plastic radiator from denso. I'll try to ask where is Denso here in cebu. thanx theeved.
    Aug 2005
    and by the way the link you just post theeved was a denso site and it has a link where denso cebu located. thanx so much theeved!
    Im not sure, why not drop them an email, baka meron silang branch dun, if not, ask mo din kay Vince siguro if you can arrange for door-to-door, baka pwede.
    Aug 2005
    The Civic's stock radiator is an aluminum unit with crimped plastic end tanks.
    Normally, unless some idiot does something stupid like lean heavily on an overflow pipe, fiberglass reinforced plastic is pretty tough, and the common causes of leakages would be worn gaskets.
    Replacing the tank with a brass replacement or even steel (supposing they can actually weld it without using any exotic alloy) would be a death sentence to your radiator and your aluminum block because of galvanic corrosion. More active metals will make aluminum a sacrificial anode. Though coolants minimize the possibility of this by being a dielectric solution, you can't ignore the possibility.
    I suggest just buying an aftermarket replacement radiator, it doesn't cost that much for a brass/copper unit. Unless of course you're weight conscious as the brass/copper unit weighs over twice as much as its Al counterpart.
    Feb 2006
    EVO-V
    I am really amazed at the technical knowledge you and others have on this field...thanks for your advice, you and speedy fix are right, i should also consider just replacing the unit if the cost is not that much more.....i will also check the gaskets (i am assuming they can be replaced).....
    i have a feeling some fool must have leaned on it while replacing the spark plugs or something like that......
    I didn't know that Denso is replacing plastic top of radiator... sayang 'yong Corolla namin tanso na ang ibabaw ng radiator niya... hmmm.
    Nov 2003
    price will depend kung single or 2 row tsaka kung manual or matic yung car. give the shop a call for an estimate.
    Aug 2003
    sino hahanapin kung pa estimate crv oto ko matic po..
    Nov 2003
    we got an order for a crv today... was that you? tom daw kakabit. hehe!
Convert Radiator from Plastic to Steel?
