Results 11 to 20 of 20
September 3rd, 2017 05:44 PM #11
Madami na binigay na recommendations above, take note of that para may basis ka.
Have it checked sa aircon shop. The unit is almost 17 year old madami na need i double check once na mapagalaw mo yan.
Didn't they recommend to replace the filter drier and expansion valve nung pinalinis mo?
Yan kasing 2 part na yan ng a.c., although optional na palitan, madalas pinagsisimulan ng problem kapag hindi pinalitan ng sabay kapag nagpabaklas ka.
Sent from my ASUS ZenFone 4 using Tapatalk
September 3rd, 2017 05:56 PM #12
Cleaning madalas gawin pag mahina buga ng hangin, either madumi, barado kaya nagyeyelo, happened to me kaya nung napalinis na ok na ulit ang buga.
September 3rd, 2017 06:16 PM #13
- May 2011
- 481
September 3rd, 2017 06:29 PM #14The question is about air flow or air discharge delivery.
The air velocity and volume is also affected by cabin pressure. Is the symptom the same whether the doors are open or closed?
The air discharge flows from the evaporator then to the heater. If either is clogged or restricted the discharge will be weak and if the refrigeration function is working okay, the evaporator freezes up and the symptom gets worse. At high blower speed the discharge air should be strong enough to blow your one hundred peso bill or other paper money away.
- 54,289
September 9th, 2017 04:47 PM #16
airflow or air volume ata problema ng TS doc. If may problema ang drier filter that means barado na ang liquid line ng system, that or baliktad ang pagkabit ng drier filter. Isang symptom ng faulty drier filter is short cycling ng compressor, forming or ice sa evaporator and the low pressure side pipes and most of all di masyado malamig ang buga kahit malakas ang volume ng hangin.
- Oct 2009
- 2,271
September 9th, 2017 07:07 PM #17kung malamig naman at mahina ung buga ng hangin..palitin ng fan motor yan.ganyan din angyari sa honda ko dati.humina ung buga ng hangin.upod na ung carbon ng blower or palitin na talaga..
tip wag ka ng bibili ng surplus na halaga 500-800 ang presyo .bumili kana lang ng bago may nakuha ako dati 2,5k ayun nag tagal siya hanggang sa nabenta ko na ung tsikot ..
February 22nd, 2018 11:51 AM #18
what if reverse scenario naman, wherein normal lahat (malakas ang buga ng hangin at malamig din) pero kapag napadaan sa lubak na kalsada, after a few seconds eh mawawala na yung lamig at hangin na lang ang lumalabas sa aircon. Ibig bang sabihin nito kulang na yung freon?
February 22nd, 2018 12:04 PM #19
February 22nd, 2018 12:46 PM #20
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
