Results 1 to 10 of 20
- Apr 2015
- 12
September 3rd, 2017 09:47 AM #1Title : Mahina buga ng fan/aircon
Car: Honda Civic 1999
Problem: Newbie lng po. Ano po pwedeng gawin kung mahina buga o labas ng hangin ng fan o aircon.. may lamig nmn pero parang mahina lang.. salamat guys..
- 54,290
September 3rd, 2017 09:56 AM #2the last time this happened to my (non-honda) car, it was because someone installed a wrong-type replacement evaporator.
medyo malamig ang hangin, but still "hilaw". and because the evaporator iced up, pahina nang pahina ang buga ng hangin.
replacing the evaporator with the correct one, restored everything to factory spec.
September 3rd, 2017 10:09 AM #3
I'm not familiar with your vehicle but the principle sa lahat ng sasakyan is similar. If may cabin filter ka check mo yun baka marumi and barado na. If walang cabin filter then probably barado or marumi na evaporator fins ng aircon mo. Pwede din mag cause ng low air volume ang marumi fan blower or mafunction ng air damper sa aircon duct na hindi naka full open. Those are only some of the causes but not limited dun sa mga binangit ko.
September 3rd, 2017 10:15 AM #4
Meron ka na ba pinagawa prior to this incident?
Or first time ito nangyari?
Sent from my ASUS ZenFone 4 using Tapatalk
- May 2011
- 481
September 3rd, 2017 10:45 AM #5Use gauges, numbers are numbers regardless you're Korean, Japanese, Dutch, German or Mexican. Calibrated gauges don't lie.
Check the system voltage with the engine running at the battery terminals. Then check the voltage at the blower motor connector or terminals. The voltage should not be lower than 0.1 volt below source voltage while under load. If it is lower than source voltage minus 0.1, correct the voltage drop first. If the voltage falls within ball park figure, check the air flow or restrictions.
September 3rd, 2017 11:45 AM #6
Baka kulang na ng supply ng kuryente aircon motor mo.... or kulang sa ground... rekta mo muna to check...
- Apr 2015
- 12
September 3rd, 2017 01:16 PM #7nakuha ko ito sasakyan 2 yrs ago.. last feb nagpalinis lng ako and freon.. wala nmn repair or replacement ng parts..
September 3rd, 2017 02:03 PM #8
September 3rd, 2017 04:13 PM #9
ac motor is 17yrs... mechanical wear and tear...
- Apr 2015
- 12
Are they on track to surpass last year's sales?
Car Sales Data (2025)
