Results 1 to 5 of 5
    Apr 2012
    hello,,hihingi sana aq ng tulong sa in u.my leak kasi ung reserve tank ng radiator ng kotse q.sa my bandang itaas malapit sa my takip nya,pwd ba syang lagyan ng epoxy?please,, can i have some advice kng anu dapat gawin?ang dami kasi'ng tubig na lumalabas doon..
    bili ka na lang ng surplus
    Apr 2012
    bukod ba ung reserve tank,pagbibili ako?
    Jul 2003
    make sure it is a leak. because it may just be some coolant overflowing which happens when you put water or coolant above the max level.
    if there is indeed a leak, you can try putting epoxy. I always use epoxy steel.
    or buy a new one. around Ph500 for older sedans.
    bakit nagoverflow diba dapat bandang kalahati lang ang laman nito?
leak radiator reserve tank
