Results 1 to 9 of 9
    good day sir, parehas na parehas tayo ng problem.. kakapagawa ko lang din yung a/c ko and nagpalit ng compresor, similar to you yan na yan din sabi sa akin ng mga a/c specialist at mekaniko dahil bago pa daw compresor later on daw e mawawala na din.. but parang may something kasi na hindi ok kaya i tried to search for some ideas, ask ko lang po kung ano yung balita sa compresor nyo? ano ano po ginawa and ok na po ba sya ngayon? thanks.
    Aug 2004
    I think the Sanden 507 is a piston-type compressor. Piston types are noisier than the scroll type that might have been what was originally installed in the car. They also take a bit more power to turn. Piston types are cheaper than scroll types though.
    piston:
    scroll:
    IIRC the TRS090 has the same fittings and mounting points as the 507. I got mine brand new for around 10k 5 years ago.
Humming sound/ Choked Engine when a/c is on
