Results 1 to 10 of 14
- Feb 2008
- 577
June 11th, 2008 04:13 PM #1hi,
are there any other ways of telling that you are running low in refrigirant besides loss of cooling?
in my case kasi, i do not feel any loss in cooling, but here's the observation...
whenever the a/c engages (the compressor turns), the engine would idle erratically (even though its running at 900 rpm). no noise in the compressor. as for the frequency of clicks (engagement of the a/c clutch), i can't tell.
June 11th, 2008 04:39 PM #2
June 11th, 2008 04:39 PM #3
sorry double post...
- Feb 2008
- 577
June 11th, 2008 07:44 PM #4for how long should the a/c be running? or should it be evident as soon as i turn it on?
June 12th, 2008 01:59 AM #5
how can you tell if you have low refrigirant?
hi,
Pag walang refrigerant sa system, the compressor wont turn on
June 12th, 2008 05:38 AM #6
sa window sa dryer it should have a clear to a few bubbles it means ok pa ng freon level. pag puti na sa sobrang dami ng bubbles bawas na ang refrigerant mo.
June 12th, 2008 06:57 AM #7
mga sir is it normal na pag naka idle hindi masyado malamig ang a/c for diesel engines ..?
- Jan 2008
- 380
June 12th, 2008 09:47 AM #8mga sir is it normal na pag naka idle hindi masyado malamig ang a/c for diesel engines..?
'Sight glass diagnosis' may not apply with R134 systems the best thing to do is to use the aircon service gauges and compare it with your vehicle specifications.
As to the erratic idling of 'spyghost' , it could be related to spark or fueling problem, vacuum leaks can also be a culprit. These could adversely affect the idle-up control of the engine as the aircon is switch-on especially with those having non Variable Displacement Compressors (VDC).
BTW, paano ba idle-up mechanism ng kotse mo sir spyghost. Meron bang mechanical or vacuum linkage sa accelerator, throttle opening or carburator, pwede ba i-adjust manually yung idle-up RPM.
June 12th, 2008 12:07 PM #9
ako naman pag a/c naka open parang hirap humatak. pinagawa ko kay mang mario yung a/c ko full cleanning pa nga pinagawa ko dun at nagpalit narin ng dryer. anu kaya prob dun.pag patay naman a/c di naman hirap.
pls help.
June 12th, 2008 12:21 PM #10
kung nababawasan ang freon then better have it fix na...since a/c system is sealed hinde pwedeng mabawasan unless meron leak na somewhere...
Ayala North Exhange. May parking levels siya na available for the public. Then may RCBC, GT...
Makati CBD parking
