Results 1 to 10 of 14
- Sep 2006
- 23
September 21st, 2006 08:51 PM #1ano kya problema ng aircon ko bkit twing i-on ko aircon ko bumababa yung rpm ko
September 21st, 2006 09:42 PM #2
hindi ba dating ganyan? usually bababa talaga ng konti ang rpm because of the added load kapag nag-ON ang aircon. pero konti lang dapat.
kung malaki ang binaba ng rpm mo, baka malapit ng mag stuck up yung compressor mo and the engine is having a hard time turning the compressor kaya malaki ang binaba sa rpm.
September 21st, 2006 10:22 PM #3
Kung efi ang unit mo e sensor or ecu ang may problema dyan. Kung lancer singkit yan e servo or trottle body may problema dyan.
- Sep 2006
- 19
September 21st, 2006 10:55 PM #4one of the solutions can be, if that is carburated one, attach a "step-up" inaangat niya ung idling ng engine once na i-turn on mo yung aircon...
- Sep 2006
- 23
September 21st, 2006 11:21 PM #5toyota xe unit ko, carburated. d kya yung equator ko yung problm. tsaka what meant pla dun s bumama yung rpm is yung tachometer reading ko. d b dpat pumalo pataas yung tach ko kya lng yung akin bmbgsak kpg ngaircon ako. can i mechanic solve this or i should bring it to a aircon specialist?
September 21st, 2006 11:33 PM #6
go to a trusted mechanic first to let him rule out compressor problem. kung compressor daw talaga ang may problema, tsaka ka pumunta sa aircon specialist.
September 21st, 2006 11:59 PM #7
check mo muna yun idle up/vacuum switch mo. it should work when you turn on your a/c. this would compensate for the added load of your compressor. if you can't find it take it to a reputable aircon shop ike mang marios or the bankers in marikina.
September 22nd, 2006 03:01 PM #8
September 22nd, 2006 05:31 PM #9
pakiramdaman mo kung sinasalo ng idle up mo once umikot
ang compressor mo. if not pa-check muna sa mech ang idle up
as sir boybi said. 2nd option lang ang a/c shop.
- Oct 2006
- 43
October 2nd, 2006 02:31 AM #10not sure lang kung pareho a/c system ng carb and efi. pro meron ako corolla GLi dati, ganyang-ganyan ang problema. napansin ko may leak (hangin) sa tubing papunta idle-up. pag tinakpan leak (or better yet palitan yung tubing), normal na sya.
VinFast VF 3
