Results 1 to 10 of 14
- Sep 2006
- 23
September 21st, 2006 08:51 PM #1ano kya problema ng aircon ko bkit twing i-on ko aircon ko bumababa yung rpm ko
September 21st, 2006 09:42 PM #2
hindi ba dating ganyan? usually bababa talaga ng konti ang rpm because of the added load kapag nag-ON ang aircon. pero konti lang dapat.
kung malaki ang binaba ng rpm mo, baka malapit ng mag stuck up yung compressor mo and the engine is having a hard time turning the compressor kaya malaki ang binaba sa rpm.
September 21st, 2006 10:22 PM #3
Kung efi ang unit mo e sensor or ecu ang may problema dyan. Kung lancer singkit yan e servo or trottle body may problema dyan.
- Sep 2006
- 19
September 21st, 2006 10:55 PM #4one of the solutions can be, if that is carburated one, attach a "step-up" inaangat niya ung idling ng engine once na i-turn on mo yung aircon...
- Sep 2006
- 23
September 21st, 2006 11:21 PM #5toyota xe unit ko, carburated. d kya yung equator ko yung problm. tsaka what meant pla dun s bumama yung rpm is yung tachometer reading ko. d b dpat pumalo pataas yung tach ko kya lng yung akin bmbgsak kpg ngaircon ako. can i mechanic solve this or i should bring it to a aircon specialist?
September 21st, 2006 11:33 PM #6
go to a trusted mechanic first to let him rule out compressor problem. kung compressor daw talaga ang may problema, tsaka ka pumunta sa aircon specialist.
September 21st, 2006 11:59 PM #7
check mo muna yun idle up/vacuum switch mo. it should work when you turn on your a/c. this would compensate for the added load of your compressor. if you can't find it take it to a reputable aircon shop ike mang marios or the bankers in marikina.
September 22nd, 2006 03:01 PM #8
September 22nd, 2006 05:31 PM #9
pakiramdaman mo kung sinasalo ng idle up mo once umikot
ang compressor mo. if not pa-check muna sa mech ang idle up
as sir boybi said. 2nd option lang ang a/c shop.
- Oct 2006
- 43
October 2nd, 2006 02:31 AM #10not sure lang kung pareho a/c system ng carb and efi. pro meron ako corolla GLi dati, ganyang-ganyan ang problema. napansin ko may leak (hangin) sa tubing papunta idle-up. pag tinakpan leak (or better yet palitan yung tubing), normal na sya.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
