Results 1 to 10 of 35
- Nov 2008
- 43
July 21st, 2009 02:00 PM #1Mga sir, ask lang ako ng opinion yung car ko kase 97 corolla gli napansin ko nataas yung temperature habang idle or natatraffic.
Then kahapon napansin ko na yung aux fan dun sa may radiator natakbo lang pag naka on yung aircon tapos parang mabagal lang sya tapos titigil ulit. I know para sya automatic kaso ayun nga for the mean time ang ginawa ko eh tinanggal ko muna sa thermostat sensor ba yun yung plug nung sa AUX fan para continious sya natakbo. Ok naman sya nde na nanataas yung temperature nasa kalahati na lang unlike nung last time para na syang nakulo.
Ang question ko do i need to replace the thermostat sensor or need ko pacheck muna wirings ko? Nagtataka kase ako pag naka aircon lang natakbo tapos mahina pa.. pero nung ni disconnect ko sya dun sa thermostat sensor ang tulin ng takbo.
Thanks in advance.
July 21st, 2009 02:22 PM #2
Bro just want to ask diba you said you took off the connectors coming from the fan to the thermistor sensor and you just connect it directly to each other and your fan spunned fast. Maybe you need to use a relay because a thermistor sensor ould only allow little current to pass onto it thats why your fan turned but just slowly. just my opinion.
- Nov 2008
- 43
July 21st, 2009 02:52 PM #3
July 21st, 2009 09:25 PM #4
- Nov 2008
- 43
July 22nd, 2009 08:05 PM #5Hi Mga sir,
replaced the thermo switch tapos pinalitan ko na rin yung radiator cap just incase and mukhang ok na sya.. natraffic ako sobra kanina ni nde lumampas ng kalahati yung sa guage ko.
- Apr 2015
- 6
- Jun 2014
- 414
May 15th, 2015 04:17 PM #8
May 15th, 2015 05:06 PM #9
less effective ang fan pag wala ang shroud. at kung wala yung shroud pwedeng umiikot lang dun sa engine compartment yung hangin so bawas ang hangin na nahihigop ng fan na dumadaan sa radiator.
May 15th, 2015 06:25 PM #10
Yun kaya dahilan ng pag overheat ng van ko pag na stock sa trafict ng mga 1 hour tumataas temp sa 3/4 pero d naman nag babawas ng tubig
VinFast VF 3
