Results 1 to 5 of 5
- Aug 2008
- 28
July 18th, 2009 08:21 PM #1everyday po lagi ako nagrerefil ng tubig ng radiator ko.. tingin nyo po ano prob??? wala naman ako napapansin tagas e// pls help... 97 big body and 99 crv po gamit ko
July 18th, 2009 08:26 PM #2
either you have a leak sa cooling system or may problema na radiator cap. what my mechanic friend taught me was to put red food coloring sa radiator. kung saan may lumabas na red color dun ang leak.
July 18th, 2009 10:12 PM #3
did your crv encountered over heating previously? if yes, chances are your reservoir plastic tank is always full while the radiator is lucking in water. if this is your condition, then your cylinder head is warp or either gasket is leaking. get the cylinder head resurfaced & replace new gasket.
i'm talking to experience. experienced the same in my city & crv as well.
- Aug 2008
- 28
July 19th, 2009 09:43 PM #4
July 20th, 2009 10:38 AM #5
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
