Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Feb 2010
    Guys,
    1) what do you expect to be clened(specific parts)
    2) any replacements (included in the fee)?
    3) refill of freon?
    4) how much?
    TIA!! just want to compare......
    I just my car's a/c cleaned 2 weeks ago. The evaporator, cooling coil and blower were dismantled. No parts were replaced. The cleaning was mostly done on the cooling coil (using a chemical). The evaporator and blower were dusty and just cleaned with compressed air. The compressor was given a top-up of oil and the system was filled with refrigerant.
    Nov 2007
    Quote Originally Posted by PSI View Post
    Guys,
    3) refill of freon?
    4) how much?
    pag cleaning..evaporator unit..walang papalitan kung cleaning lang.refill ng freon at additional na langis..aabutin ka ng 1,200 kung r134a ang freon at 800 kung r12..yan ang estimate sa ride mo kung single unit lang..txt mo ako at bibigyan kita ng discount..
    Feb 2010
    Quote Originally Posted by gorionikoy View Post
    boss san po shop ninyo? marikina po kasi ako....
    medyo nalalayuan na kasi ako kina mang mario eh...
    question po... masama ba pag lime ang ginagamit sa paglinis?
    Nov 2007
    oho tutunawin nya mga fins at mga tubo ng cooling coil..pinaparenovate pa ho garahe..sana mabisita nyo ako pag ok na..salamat
    Feb 2010
    boss saan shop mo? tapos na ba?
    Dec 2007
    If there's anything to replace in an A/C cleaning job, it's usually the expansion valve. If you're lucky, you won't have to, but the dirt circulating in the system can get to such a level that a replacement may be necessary.
    Aug 2010
    sir normally po ilan months ang next servicing ng aircon para ma maintain stability ng aircon, meron po ba sinusunod na mileage o buwan po ba...paki advise naman po..tnx
    Nov 2007
    Quote Originally Posted by wenweng View Post
    sir annual check up at cleaning is a must..
    Nov 2007
    mga sir ok na ho,pwede nyo n rin akong bisitahin http://www.facebook.com/note.php?cre...65917003429687
cleaning of AC
