Results 1 to 14 of 14
    Feb 2012
    Mga sir wala kaya magiging prob pag nag dagdag ng radiator at malaki kaya maitutulong nito lalo sa mga lumang van para pag biglang pumalya ang cooling system Hindi agad mag oover heat Hindi kasi ako kampante pag iba hung nag dradrive lalo pag longdrive pa,
    Gagamit lang ako ng maliit na radiator mga sir tulad ng nasa pic
    Feb 2012
    Quote Originally Posted by sotel View Post
    BTW mga sir dito ko ilalagay yung linya ng radiator
    Apr 2010
    Kung may existing heater core ka na, pag nag ooverheat ka pwede mo i set ang aircon temp all the way to hot para ma divert yung extra engine heat sa vents mo
    Kung hindi ka kampante sa coolig system mo eh bili ka na lang ng bagong radiator and other parts like waterpump, band aid solution lang IMO ang plan mo
    Jun 2006
    Useless din backup yan, kasi iisa ang water Pump at engine block, water passes thru the same route, pag nabutas ang isang radiator, lahat ng tubig dun lalabas.
    To have a backup cooling system you must have 2 isolated cooling system.
    Pde yan,supplemental, pantulong.
    Feb 2012
    Quote Originally Posted by ParticleX View Post
    Pansin ko kasi sir kahit good condition lahat kung puro 1st gear at 2nd gear lang na 30mins na uphill with ac mag ooverheat pa din tapos naka capacity pa hehe
    Feb 2012
    Quote Originally Posted by shibby75 View Post
    Naisip ko gayahin yung urvan dalawa daw radiator nun hehe
    May 2009
    baka condenser ng A/C kamo iyong sa urvan....
    ok na iyan na kahit walang heater core. basta well maintained ang mga pyesa ng cooling system gaya ng water pump, coolant, drive belts, auxiliary fan, temp gage, hoses, radiator, at syempre yung thermostat.
    Jan 2009
    May instance na ba na tumaas ang temp beyond the normal level during uphill driving on 1st and 2nd gear?
    Kung hindi naman, maybe you're worrying too much.
    Feb 2012
    Meron sir lalo pag 30mins na uphill tapos puno karga with ac lalagpas sa kalahati temp pero wala bawas sa tubig
    Feb 2012
    BTW wala pala thermostat van ko wala din fan shourd nung nakuha ko
    Oct 2009
    may DIY dati akong ginawa sa owner type jeep ko..
    bumili ako ng surplus water pump washer..at bumili ako ng break tube lines saka ko binutasan ng maliliit saka ko binaluktot tulad ng nasa likod ng mga refrigerator nung araw..ganun naging itsura niya.saka ko itinabi sa radiator ko..ngayon may nabibili naman na thermo switch.dinidikit lang din sa radiator un..kapag na reach na uminit ang radiator mag ki click ang thermo at ma isu switch niya ung washer pump na naka kabit dun sa tube na may butas..
    ikaw na bahalang dumiskarte..sa lagayan ng tubig..sa akin galon ng langis ung nilagyan ko para 4 liters.
    nakita nga ni kumpare at nagpa gawa din siya..ng wiring sa akin siya na dumiskarte dun sa water tube na may mga butas,,,
    that is why your temperature goes up..
    Feb 2012
    Mga Sir maraming salamat po sa tulong niyo OK na po van ko hanggang 1/4 temp nya pag naka idle ng 1hour tapos pag tumatakbo na nasa pinaka baba na ng temp Bali pinalinis ko po radiator at nilagyan ng radiator shourd
    Feb 2012
    Ngayon kelangan humanap ng genuine na thermostat para lagi nasa normal operating temp 🙌
heater core convert to sub radiator
