Can anyone help me out here. What can I use as a replacement for the heat shield under the hood? Thanks
Kung may budget ka: Dynamat or Dynaliner. It's a bit lighter than 'flashband.'
based from the official website
1/4 " thickness
Contents: (1) 32"x 54" x 1/4" (813mm x 1372mm x 6.35mm) Dynaliner Sheet
Total Coverage: 12 ft² (1.11 m²)
Price: $70.00 US Retail
just by the heat insulator from your dealer, hinde naman masyadong mahal yan probably will cost 2k+ lang
is the dynaliner available locally (aside from true value makati)?
One more problem wala na rin yung mga plugs and clips. where can I get those kaya?
As far as I know, Dynamat and Dynaliner are self-adhesive. Best to clean the metal surfaces with solvent (e.g. alcohol or acetone) beforehand, and use a rubber roller to eliminate air bubbles/pockets and promote better adhesion.
Dynamat is usually used for noise-reduction purposes...what car audio buffs call "deadening." Dynaliner is for heat reflection/containment.
CMIIW
AFAIK there's an existing thread about this topic, anyway, attached is what I did to my former Civic EG.
yun din ba yung parang itim na rubberized paint sa ibabaw ng battery area?
patanong na din guys, para san ba yan? i've seen most cars meron tas yung iba wala
