Results 1 to 20 of 29
Threaded View
    Jun 2006
    Add ko lang. Yung engine temp guage ay malaro, up and down by a few degrees. And when my driver changed the radiator cap, the coolant overflowed.
    What do you guys think?
    Update lang, had the car's radiator pressure tested, no leaks. Mechanic inserted a temp probe in the radiator, coolant temp was at 220F and the fans were not yet turning, AC off. Engine temp went 2 notches above 1/2 before the 2 fans turned on, AC off. Turned on the AC both fans ran and temp guage went to below 1/2.
    He said there is no blockage in the radiator as the temp should not normalize if its blocked. Tama ba? He is thinking that the new thremoswitch's setting is too high. Over 1/2 before fans kick in when AC is off. He also wants to replace the thermostat. Opinons please.
    Last edited by userfriendly; April 28th, 2007 at 08:22 PM. Reason: update and correction
heat problem
