Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 101 to 120 of 179
    #101
    i removed my theromstat a few months back. ngayon gusto ko ibalik.
    sobrang tagal umakyat ng temp e. plus from what ive read, may kaba na ako whenever sa traffic ako tapos maaraw. feel ko hindi nacoo-cool ng maayos yung tubig.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    #102
    Agree ako kay Speedyfix. Wag nyong tatanggalin pareho. Kaya lang both should be on their proper specs. Yung Thermostat sa ibabaw ng makina, nag activate yun pag umiinit , lumalamig makina , ang alam ko may wax sa loob yun or any material na nag eexpand para bumukas at sumara. Yung thermoswitch, there is a certain temperature na mag on sya, thus connected to a relay or direct to radiator fan. Malaki epekto nyan sa performance at longevity ng makina, maski gaanong kalaking makina.
    Sabi nila pag sa Pilipinas, di na kailangan dahil mainit ang panahon. Kapag summer dito sa Japan mas mainit pa kaysa dyan sa atin, bakit di naman ginagalaw ng mga Ponjaps yan. Takbo nga lang ng takbo sila.
    Regarding sa kung saan bibili ng thermostat for a certain car para masiguro kung tama, yun ang problema, parang takip ng radiator, para makasiguro ako, dito ako sa Japan bumibili. Sa casa meron nyan, medyo mahal siguro.
    Domo arigato gozaimasuta!
    Apr 2006
    #103
    Info about thermostat.
    The thermostat's main job is to allow the engine to heat up quickly, and then to keep the engine at a constant temperature. It does this by regulating the amount of water that goes through the radiator. At low temperatures, the outlet to the radiator is completely blocked -- all of the coolant is recirculated back through the engine.
    Once the temperature of the coolant rises to between 180 and 195 F (82 - 91 C), the thermostat starts to open, allowing fluid to flow through the radiator. By the time the coolant reaches 200 to 218 F (93 - 103 C), the thermostat is open all the way.
    If you ever have the chance to test one, a thermostat is an amazing thing to watch because what it does seems impossible. You can put one in a pot of boiling water on the stove. As it heats up, its valve opens about an inch, apparently by magic! If you'd like to try this yourself, go to a car parts store and buy one for a couple of bucks.
    The secret of the thermostat lies in the small cylinder located on the engine-side of the device. This cylinder is filled with a wax that begins to melt at around 180 F (different thermostats open at different temperatures, but 180 F is a common one). A rod connected to the valve presses into this wax. When the wax melts, it expands significantly, pushing the rod out of the cylinder and opening the valve. The wax just expands a good bit more because it is changing from a solid to a liquid in addition to expanding from the heat.
    problema ko 'to ngayon. i'll try to diy this as soon as i can. pati iyong thermoswitch damay din...anak ng chikiting wakwak talaga
    readily available ba iyong mga iyan sa ating mga friendly auto shops? magkakano kaya (ek iyong auto)?
    Jun 2007
    #105
    Yung replacement P550 lang each for thermostat and thermoswitch. sa CASA nasa P1200+ yung switch.. yung thermostat naman nasa P1100+
    Aug 2005
    #106
    Quote Originally Posted by jason7100 View Post
    if this is the case... what is the function of the thermostat? isnt this the one which turns on the fan? thanks!
    nope! thermoswitch un the one that controls the fan. ang thermostat works as temperature controled valve, sa right temperature magoopen cya para pumasok cool water sa engine at same time pagbumaba na temp ng engine nag cclose naman cya nireregulate lang nya na dapat na nsa certain level ang temperature ng engine, wlang pnagkaiba yan sa trabaho ng fuel regulator ng fuel rail ng mga efi engne ngayn cya nman minimaintain nya ung psi level sa fuel rail pra sa pagbukas ng injectors.
    sa mga diesel or carby engine masmagandang wala ng thermostat sa hot climate na lugar like d2 hindi mo kylangan pinitin pa mainit na d2 e hehehe at same time dpa kagad andar ng andar radiator fan maslalo na pag rekta takbo mo.
    may problema nga lang pag sa EFI engine pagwlang thermostat ung temperature controled na idle up ang tagal mag automatic kc hinihintay pa ng cmpter box thru temperature sensor na magnormalize sa tamang heat ang engine kaya ang taas ng idling, bad trip yan pagmatic ang tranny mo at mlakas kpa sa gas sir.
    #107
    doc otep, did you notice a dramatic change in your car's performance when you put in a new thermostat? my car hasn't had a thermostat the past 5 years and i haven't noticed anything wrong however your arguments are both valid and sound so I am seriously considering putting in a new one.
    Aug 2005
    #108
    ang nagging problema nga lang sa mga old cars pagmay thermostat by the time na nalaman mo na sira na ang thermostat ay nagoverheat kna sa highway, nagstockup yan ng close or minsan halfway kya dmo alam ngooverheat kna pla ng dahan2
    #109
    I recorded improved mileage on the Land Cruiser (from around 4-5km/L went to around 6++). This was based on real world driving and not a lab experiment so other external factors could have been involved. As for performance, I couldn't discern much difference. Still felt like the slow 100hp truck it used to be. hehehe.
    Aug 2005
    #110
    agree ako jan, mkktipid ka sa 1st 10-20mins lang mula nung nagstart engine ka, with thermostat by 3mins nsa normal operating temperature na ang engine while without thermostat it will take 10-25mins pra mrating nya ang normal operating temperature kaya mataas idling, depende pa yan sa laki ng radiator masmalaki masmatagal
    any tips or precautions on how to apply the silicone gasket maker? wala kasi akong mabili na gasket for the thermostat assembly housing kasi replacement lang binili ko even though orig iyong thermoswitch na binili ko:transform:
    #112
    You can buy per foot then just cut out the shape of the gasket. kung may yellow folder kayo pwede na rin. Manipis na manipis lang silicon para hindi mag drip.
    finally found a shop that sells oem thermostat gaskets separately
    had this irritating problem DIY'ed earlier today. had a little roadblock w/ 2 loose thread screws w/c i replaced. pretty darn sweat inducing work but immensely satisfying though (babaw ng kaligayahan ko):rofl:.
    fortunately, i was able to finish the whole exercise before the ateneo-dlsu game
    #114
    Quote Originally Posted by ritek View Post
    bossing, san ba located un thermoswitch ? madali lang ba palitan ito (as in DIY) ? thanks.
    Jul 2006
    #115
    One thing I'll do is swap the thermostat for a lower rated stat for the summer, then do another swap for the cold winter (in the US). I already have two stats waiting for me, both Behr, one rated at 80C, one at 72C. Just got the lower rated one sa Delodur while I'm in Manila...
    Feb 2006
    #116
    reading this thread bigla ako nagalala, so i checked my radiator, i opened the cap and started the engine, water kept on circulatring. so i'm guessing my thermostat is busted?
    Aug 2005
    #117
    Sabi nila pag sa Pilipinas, di na kailangan dahil mainit ang panahon. Kapag summer dito sa Japan mas mainit pa kaysa dyan sa atin, bakit di naman ginagalaw ng mga Ponjaps yan. Takbo nga lang ng takbo sila.???
    Aug 2005
    #118
    maraming kokontra ata jan sir
    iba design ng engine jan sa japan, nka design for cold climate at ung satin pang humid or hot climate. kya may nagging problem ang mekaniko d2 pagconversion ng diesel engine maslalo na pag turbo diesel pagroadtest nagooverheat kagad kaya ung iba tinatangal na ung turbo or convert sa 4 or 5 rows na big radiator dahil sayang ung turbo.
    mga ponjaps mautak tlaga pag ang engine e para sa europe,us or skanila ang daanan ng tubig like sa cylinderhead konti lang or nkacondemn ung iba or masmaliit ang circumference ng butas kaysa sa engine na nand2 satin
    Aug 2005
    #119
    Quote Originally Posted by recklus View Post
    malamang natanggal na ng mekaniko yan hehehe or nag stockopen, kadalasan magloko yan stock minimal open makikita mo yan mdyo ala sa normal ang temp gauge mo hangang bgla kna lang overheat
    Feb 2006
    #120
    had it checked kanina, ala nga thermostat, nagulat ako since i acquired it brand new at ako lagi nagpapagawa nung kotse tas lagi ko binabantayan, pero imposible naman lumabas sa casa na di nila nilagyan di ba? i'm thinking it was removed when general overhaul was done
    anyway nakakuha ako orig for 480 and had it installed, syempre nakipagdebate pa sakin mga mechanic sa gas station not to install anymore, mas lalu lang daw magooverheat. nung ala sya thermostat the temp would play from C position (hi-way driving) to half(moderate traffic) and almost H in bumper to bumper traffic. now na meron na constant 1/4 temp indication, natraffic pa ko pauwi, i'm glad i had it installed!!!
The Great Thermostat Debate [Merged]
