Results 1 to 20 of 22
    hindi pantay ang lamig ng front and rear A/C ko. what could be the probable causes aside from the difference in evaporator coils? sobrang lamig ng front A/C ko compared to the rear A/C. both of them naman were cleaned at the same time, last month lang. as a matter of fact, yung evaporator coil ng rear A/C is the one used in Nissan A/C system
    Jul 2003
    Ano ba ang sasakyan mo, pa check mo yung Solenoid Valve sa Rear Aircon baka barado na.
    Hyundai Galloper po, the re-badged Pajero boxtype. i remember my technician told me before na tinanggal nya daw yung solenoid valve, so kahit naka-off yung rear A/C, nag-cicirculate parin ang lamig on both front & rear coils.
    another technician told me na dapat daw front and rear expansion valves are the same para pantay ang lamig, how true is this?
    Jul 2006
    Nakabukas ba vents sa likod?
    that is the side effect of removing the rear solenoid valve. hihina talaga lamig ng front and rear a/c mo. actually malamig rin naman ang front kaya lang it is cooler if there is a rear solenoid valve installed. kasi it cut-off the flow from the rear evaporator when not in used..... buy a new one and have it installed. hindi naman kamahalan siguro ang part na yan dahil P900 lang kuha ko when i replace my starex's rear solenoid valve.
    i dont understand how the valve affects the coolness of the rear A/C? diba you said its only purpose is to cut off the flow kung hindi ginagamit ang rear A/C? so without this, it's free flowing from front to rear. kaso ang rear A/C ang hindi masyadong lumalamig kahit free-flowing sya, yet there's nothing wrong with the front A/C, it's soooo cold. could there be any other culprit?
front A/C is cooler than the rear
