Results 1 to 5 of 5
May 3rd, 2010 02:38 PM #1
ano po usualy ginagamit na Freon/Oil ratio ng mga technician kung walang manual/info tungkol sa sasakyan.
May 3rd, 2010 02:49 PM #2
May 3rd, 2010 05:04 PM #3
subic townace po, 1995, single converterd to dual.
1. both condensers are aftermarket,
2. the original left is only the front evaporator.
3. the front condenser is a bit huge compared to the original. about 14x22" inch
4. rear condenser is about 7x14"
May 3rd, 2010 07:37 PM #4
i would assume you have two evaporators too. your van is part frankenstein per se. unless somebody else has a better idea, i would start witj 5 ounces of PAG oil and as a reference for a YR22, refrigerant would be between 2.54 to 2.7 pounds and for a previa between 3.0 to 3.2 pounds of refrigerant. i don't know which one is closer. but you probably can base it on the pressure gauges at 27 psi on the suction side (R1234a) or 32 psi on the suction side (R12). it is very difficult to be precise if you just pick and choose evaporators and condensers. what you can do is try to be within the ballpark figure and adjust pressures accordingly. that is, with the system stabilized, run a huge fan in front of the condenser simulating ram air. i hope you can find the sweet spot for your aircon
May 4th, 2010 01:02 AM #5
If I remember correctly, the system needs almost 2 kilos. Blast... I don't have gauges to play with. I wonder how those babies cost. Already got myself a tank, handful tools and a compresor from a refigerator.
5 ounces? wow that's a lot for me who gotten to used to see tabi-tabi technicians who just use two milk spoons.
