Results 21 to 40 of 41
    Sep 2004
    #21
    Sori mga bosign pero question ulit.
    What's the worst thing that could happen if you have an R134A air con pero what they replaced it with is an R12?
    The reason I'm asking is because, whenever I get my a/c serviced and refilled, I never check what they're filling it with (ngayon ko lang kasi nalaman na may R12 at R134A, thank you very much sa sobrang informative na Tsikot forums), so medyo concern ngayon ako if I'm suppose to get it drained and checked, haaay possible na gastos ulit
    Feb 2005
    #22
    Quote Originally Posted by albert_b
    Stuck up compressor mo Albert, that's what could happen and will happen. As I have said, the two refrigerants uses different oil/lubrication. If they put R12 in an R134a system, the PAG oil of R134a will not mix with the R12. Therefore, the lubrication will not move around the system causing the compressor to starve of lubrication at times. Parang pinaghalo mo tubig at langis. If you think they charged the wrong refrigerant, remove the refrigerant used, drain the oil and I recommend you flush the system, put new PAG oil, replace the drier, vacuum and charge with R134a again.
    #23
    Quote Originally Posted by theveed
    ... Puros non-appearance ang rehistro ko eh, I doubt that they really can enforce this kinda thing...
    heheh. ako din puro non-appearance. laging thru wheelers.
    kaya wait and see na lang ako kung talagang magiging strict sila sa enforcement.
    Feb 2005
    #24
    Saan shop mo sir zeagle?
    Btw, ang 97 lancer ba eh R12 gamit?
    We own a 97 Lancer and R134a na gamit na refrigerant. Kahit yung old 93 Gli namin R134a na gamit na namin dun.
    #25
    Weird ng 95 Altima ko R12 padin
    Sep 2004
    #26
    Quote Originally Posted by zeagle
    Aaah well it doesn't seem to be getting stucked up naman. Malamig din naman. Any other symptoms that I should watch out for? Thanks Zeagle. This is really enlightening.
    Feb 2005
    #27
    If you hear unusual noise or loose cooling, stop using the aircon and have it checked immediately.
    Aug 2003
    #28
    Will they be able to tell if your car has an R12 or R134A system just by ocular inspection? :confused:
    Jan 2003
    #29
    zeagle
    so how much for typical conversion? yong retain existing compressor?
    thnx
    Feb 2005
    #30
    Quote Originally Posted by Automahn
    If they have gas analyzers they will be able to tell.
  11. #31
    guys, i dont know if we had this kind of stuff here (see URL), but it's being use on R12 to R134a conversion. They'll just suck your R12 gas out and fill it up with this fluid and this will recondition your o-rings and gaskets. I've just read it on www.mdocuk.co.uk forums so i guess if you can check this url out?
    http://www.downloadfreetrial.com/aut...etector-6.html
    #32
    Eto nakuha ko sa kabilang board...
    Sanden Conversion guide
    http://www.sanden.com/support/RETRO.html
    #33
    question, R134A na ba ang 7G galant (1996 model)?
    Jun 2005
    #34
    malalaman kaya nila na r134 na ang freon na gamit eh pwede naman pala gamitin ang r12 na compressor and pipings with only a few modifications at internal pa sa compressor. pano nila malalaman na r134 na yung aircon?!
    #35
    yun samurai ko pinalitan ng R134 kasi wala ng mabili na r12 sa marikina area. drain nila yun oil and freon, vacuum then lagay r134. ok naman siya hanggang ngayon. one month na.
    Jan 2003
    #36
    Quote Originally Posted by afrasay
    sir
    san po nyo pinagawa and how much inabot?
    freon and oil lang pinalitan?
    #37
    Dun sa D' Bankers sa Lilac st. lower Antipolo. Inabot ng 1,600 din.
    Aug 2005
    #38
    my a/c was converted by danny of danknee. aside from the oil and refrigerant change he also change the fittings for charging line of r134a refrigerant. according to danny this is the instruction of DENR to avoid confusion. however not all ac shop follow this.some shop just devise an adaptor to charge r134 to r12 fittings. yes there low quality r134 from china . the tank is only labelled "refrigerant" and no brand. make sure the disposable tank you are using is branded.
    #39
    can we stick this thread and revive? dead links na kasi yung old posts.
    Thanks
    May 2016
    #40
    Quote Originally Posted by sirkosero View Post
    fake r134? pano magkakaroon nito? hmmm... baka naman they charge u for charging pero kulang ang nilalagay na charge? baka yun ang meaning nila kaya cheaper?
    baka yan yong mga refrigerant na recycled...galing sa ibang appliance system na may kasamang moisture and oil kaya mura
FAQ: R12 to R134A CONVERSION...
