Results 1 to 10 of 12
December 20th, 2011 05:49 PM #1
My Starex airconditioning system went kaput.
Compressor shaft seal(?) is the culprit according to the technician.
According to the store proprietor, there is now a proliferation of "fake freon" that would exactly result to this type of malfunction.
Is this true?
December 20th, 2011 05:59 PM #2
Fake freon? or the wrong type of freon was used?
Example, if your AC unit requires R113, the mechanic used (cheaper) R11 instead.
- Jan 2008
- 4,726
December 20th, 2011 06:29 PM #4yung mga china made yata.. compressor shaft seal naman ang problem eh baka talagang pasira na yung part
December 20th, 2011 07:45 PM #5
^^ yung nga yung sinasabi nilang fake china made pero hindi naman maging cause para ma damage yung shaft seal
December 20th, 2011 09:33 PM #6
mas matibay pa raw ung mga surplus na compressor specially denso galing japan
December 21st, 2011 11:32 AM #7
ang sumisira sa shaft seal ay sa tagal narin ng paggamit sa sasakyan normally mga 5years lifespan. shaft seal can hold pressure up to 250PSI, normal freon natin na pang auto r-12 and r-134a ay 100-120psi lang.
fake freon, maraming brand ng freon malimit sa kanila china namely SOLFRON, DAIKIN, KLEA, GENETRON marami pang ibang brand, sa planta ng sasakyan ganyan din nakikita kong gamit nila, hindi naman porke china pangit na..
December 21st, 2011 03:46 PM #9
December 21st, 2011 10:03 PM #10
Given na yan, pre.
What I was pointing is the presence of some "impurities" or whatever in some vendors of freon that may have detrimental effect on the compressor particularly the shaft seal. As you all know, such defects (i.e leaking shaft seal) warrants a replacement of the entire compressor which is high ticket item.
The technician i asked asserted that rebuilding the shaft seal won't last long and results in recurring problems.
Now, I'm asking if there are sellers of "substandard" freonand if this could lead particularly to this problem (the shaft seal defect).
Xiaomi E-Car
