Results 1 to 10 of 10
    Feb 2009
    Hi guys need help on this one...normally when i turned on the aircon it idles up (around 875 RPM)..when i'm driving around 15KM to 20 km it idles down (RPM is the same w/o aircon 750 RPM). I did adjust the idling and it works for a while and then problem occurs again. Its been 2 yrs since i have not let my aircon check.
    Please advice on this one...
    thanks in advance.
    Nov 2007
    baka sira actuator ng pajero mo?
    Feb 2009
    Quote Originally Posted by aga_cruz View Post
    paa ba i-check pag sira ang actuator?thanks..
    Nov 2007
    sir ang actuator kasi ang nagbabalance ng idler rpm kung kailangan mag adjust o hindi ngayon pag nag on ang compresor mo gagawin ng actuator maglalagay ng konting rpm para hindi bumababa ang idling sya din ang nagbabalik ng normal rpm pag pinatay ang aircon at kung bubuhayin ulit
    Nov 2007
    buti sir hindi ka namamatayan ng engine mo pag nag automatic ang compresor?
    Feb 2009
    usually ang ginagawa ku kapag bumababa ang idling everytime nag-aircon aku ay pinapatay ko ang aircon then after 5 mins on ulit then gagana naman...i check it this weekend if the problem is the actuator..
    thanks for the advice...
    Feb 2009
    You are right...the problem is the actuator...there are times that it wont engage when i switch on the aircon..that the reason why the RPM goes down . . .
    Can we still fix the actuator or just buy a new one... which do you prefer..
    Please advice...thanks...
    Feb 2009
    is the actuator the same with the valve aircon vacuum solenoid. I got this name when i inquired about the actuator in mitsubishi motors..
    Please Advice..
    thanks..
    Nov 2007
    sir bili na lang kayo ng new one mura lang naman po ito sa pregio ko bili ko 700 petot hindi ko pa alam kung napamura ako or napamahal
    Feb 2009
    When i inquired in mitsubishi actuator...sa kanila i think is the whole assembly (valve aircon vacuum solenoid) it cost around 4300..when i inquired outside the actuator cost around 400 plus..
    so i think i'll just buy the actuator alone...
    thanks again for the help...
Aircon problem on my 2nd Gen Pajero
