Results 1 to 10 of 10
- Feb 2009
- 29
May 4th, 2009 11:12 AM #1Hi guys need help on this one...normally when i turned on the aircon it idles up (around 875 RPM)..when i'm driving around 15KM to 20 km it idles down (RPM is the same w/o aircon 750 RPM). I did adjust the idling and it works for a while and then problem occurs again. Its been 2 yrs since i have not let my aircon check.
Please advice on this one...
thanks in advance.
- Feb 2009
- 29
May 4th, 2009 02:19 PM #3
May 4th, 2009 02:35 PM #4
sir ang actuator kasi ang nagbabalance ng idler rpm kung kailangan mag adjust o hindi ngayon pag nag on ang compresor mo gagawin ng actuator maglalagay ng konting rpm para hindi bumababa ang idling sya din ang nagbabalik ng normal rpm pag pinatay ang aircon at kung bubuhayin ulit
May 4th, 2009 02:37 PM #5
buti sir hindi ka namamatayan ng engine mo pag nag automatic ang compresor?
- Feb 2009
- 29
May 5th, 2009 09:25 AM #6
- Feb 2009
- 29
May 11th, 2009 10:27 AM #7
- Feb 2009
- 29
May 13th, 2009 05:41 PM #8is the actuator the same with the valve aircon vacuum solenoid. I got this name when i inquired about the actuator in mitsubishi motors..
Please Advice..
thanks..
May 13th, 2009 06:29 PM #9
sir bili na lang kayo ng new one mura lang naman po ito sa pregio ko bili ko 700 petot hindi ko pa alam kung napamura ako or napamahal
- Feb 2009
- 29
May 14th, 2009 09:11 AM #10thanks for the advice...
When i inquired in mitsubishi actuator...sa kanila i think is the whole assembly (valve aircon vacuum solenoid) it cost around 4300..when i inquired outside the actuator cost around 400 plus..
so i think i'll just buy the actuator alone...
thanks again for the help...
high idle RPM at engine start
