Page 2 of 10 FirstFirst 123456 ... LastLast
Results 21 to 40 of 184
    #21
    Daming good reviews ang Evercool. Second choice ko iyan if we couldn't find a correct radiator for the vehicle we were restoring. Pero nakahanap ako, BEHR ang tatak. hehehe.
    Apr 2006
    #22
    Quote Originally Posted by OTEP
    Bro, what is BEHR? From what country is it made?
    Jan 2003
    #23
    me store ba ang evercool?
    or sa mga banawe shops lang available.?
    #24
    BEHR is the OEM radiator for Benzes. AFAIK, it's made somewhere in Europe.
    Mar 2004
    #25
    Tried it my past ride-Toyota Corolla, it's better than OEM coz its not plastic..After using the Evercool, didn't have problems eversince...
    #26
    gregg_g: It's not better than OEM. Plastic radiators are not only lighter, they also give way to excess pressure to prevent more expensive engine damage (like cracked cylinder heads, for example).
  7. FrankDrebin Guest
    #27
    Ingat na lang sa mga old stocks na evercool.
    #28
    pag stock denso yung radiators nyo you can bring it to denso banawe pwede nila palitan yung plastic top or yung plastic bottom pag nag crack for 1.8-2k yata yun.
    Yung sa CR-V kase made by Toyo yung radiator kaya wala yung plastic top replacement available
    #29
    Quote Originally Posted by Supierreman
    Ganu katagal buhay ng rad pag ganun?
    #30
    as long as di ka nagooverheat, there's no reason for it to break. The Denso thing isn't a repair, it replaces the whole top with a new denso top.
    one reason why nasisira ang mga OEM radiator is kung binubuhusan ng tao (usually gas station attendants) ng malamig na tubig ang radiator while its still hot... kahit bakal magwawarp yan...
    #31
    Quote Originally Posted by theveed
    Diba parang nakadikit lang un tob/bottom or clip na naghohold? Or adhesive? Or both?
    #32
    Clips po.
    #33
    Quote Originally Posted by buknoy2002
    try asking sa mga sales offices ng uratex foam, baka they carry it also... I believe, iisa ang owner ng company nila. One thing for sure, di sila nagkakabit..
    #34
    di ko pa na-try evercool, pero ito na balak ko bilhin once bumigay na radiator sa kotse ni erpats..
    yung OEM denso 3-row radiator eh mga 12K sa casa
    yung sa evercool eh nasa mga 5K yata.. pang revo po pala..
    Mar 2004
    #35
    Hi Theveed, actually my reference was the longevity of the radiator, the OEM after 3 years, gave way, but with the evercool, by the time I sold the unit, 4 yrs after the replacement, was still a OK...
    Mar 2004
    #36
    #37
    Cool Spring Marketing
    129 Roosevelt ave cor. Bautista St.
    Tel # 410-1110
    JWR motor supply
    main: 1033 benavidez st. binondo, manila
    tel #: 244-0044, 2449951
    cel #: 0918-9285452, 0922-4913900
    look 4: Richmond Ong
    branch: 1438-1442 yuseco st, (formerly tayabas st) sta cruz, mla.
    Aug 2005
    #38
    Maganda tong idea ni sir theveed ah... WEll sa nalaman ko na maganda din daw yong plastic top radiator .. galing.. I think Im gonna replace the plastic top of my radiator kasi may leak na.. thanx theveed!
    #39
    OEM Rads are made of alum, kaya sya manipis coz aluminum and dissipate heat A LOT faster than copper (mga replacement)...
    For the same amount of surface, you'll need 2 rows or more columns to duplicate the heat dissipation of a stock aluminum radiator.
    Pomelo: Check your PM, sent you a lead of someone selling a 2nd hand CRV rad.
    Jan 1970
    #40
    Quote Originally Posted by STI
    behr ang tatak ng oem rad ng bmw e30 ko.
    about radiators na din.. bakit iba pa ang radiators for manual and matic cars?
Evercool Radiators?
